3-Point Hitch Static engine......
/ Static engine...... #1
humph
Hi there,
I am Kubota orientated with four machines. I use an L5740 to drive my log processor. This could be done with a static engine, thus freeing the tractor for loading/unloading. I have either the V2203 or V2403MT engines in mind. Has any one added a gearbox with standard tractor PTO output to these engines. I am looking to get about 350RPM out at 2200/2500 RPM in. Any nominations would be gratefully received.
Humphrey
/ Static engine...... #2
Kubota engines are used for a lot of stand alone applications... also placed in skid steers... You will have to come up with a transmission that you can attach OR a simple multi belt drive and electric clutch off the flywheel... I have that on a 4 cylinder ZTR mower using a Kubota engine... Works slick, with no problems & you could pick any RPM by selecting the proper pulley sizes... KennyV
Thanks Kenny,
I have yet to take the processor to bits. The standard tractor PTO drive works an hydraulic pump, and a belt driven blade. I suspect there will be no room for a belt setup given the need to anchor the engine to the three point to avoid an engine upset (60HP on stall). Since heard I need a SAE dimensioned flywheel etc.
/ Static engine...... #4
The Finn hydro seeder uses a Kubota with hand clutch to drive the pump.should be available to run a belt or attach to PTO direct.
ken
/ Static engine...... #5
The Logan Clutch Corporation - Bell Housing Series Description
iDrive TDS-2010H...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
2014 JEEP GRAND CHEROKEE (A64280)
2014 JEEP GRAND...
2006 Hypac C530AH Pneumatic Wheel Compactor (A61572)
2006 Hypac C530AH...
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
(10) John Deere Tractor Weights (A64119)
(10) John Deere...
