patrick_g
Elite Member
I saw this comment on another website and was wondering if it is true with all tractors.
Let it Idle
In cold weather, after your tractor has started, let it stand and run for a good 20 minutes. Adjust the idle up to around 1500-1700 RPM and just let it sit. The reason we do this is so that the heat of the engine dissapates into the transmission, transfer case and gear drives of the tractor. If we went to work right away, the gear oil is so thick that the hydraulics will not work and shifting gears is problematic. A common service task is to repair a shifter fork during a cold weather season the gear oil is so cold and thick that when the operator grabs the stick to put the tractor into gear, the shifter fork breaks off inside the transmission costly. Let the tractor warm up for a period of at least 20 minutes when in cold weather.
Yes but... What about hydrostats? First (applicable to all diesel tracltors), when you turn the key on the glow plug light comes on indicating the glow plugs are heating. When the light goes off quickly turn off the key and then immediately back on to give the glow plugs another cycle. This will let the tractor (in my case) start with much less cranking. Then with the engine running smoothly (well under a minute) slowly drive the tractor. No high speed, no hard work (not even up a steep hill) and only use the hydraulics (3PH or FEL or...) slowly and sparingly. As the tractor warms up the hydraulics will respond much more smoothly and you may begin normal operation.
YMMY It works for me. The coldest overnight temp prior to my using this procedure has been 0 degrees F. The tractor was parked for days in the open. No batt charger, no batt heater, no plug in of anything. I gave it 2-3 cycles of glow plug heating and it started up and ran roughly till it warmed a bit. It didn't crank real fast due to cold battery but it started nicely. I attribute easier starting to the multiple glow plug cycles. Not needed in warm weather. Not needed in cool temps but in really cold temps, it helps.
Light work after the engine is running smoothly does not cause problems. On the contrary the light work helps the tractor to warm up faster. Make haste slowly. Don't rush into HD work with a cold engine and hydraulics. A battery maintainer (float charger or better yet a charger desulfator preferably with temperature compensation) will keep the battery fully charged and make starting easier as well as extending the battery life. Do not use a high current charger for extended periods of time and do check the fluid level of batts with caps to access the fluid.
Happy winter tractoring, stay warm. I do, in T-shirt and jeans as my Kubota has a killer heater in the cab.
Patrick
