TomSeller
Super Member
My Kubota idles at a higher rpm when throttled own and the engine is cold. After warming up it idles at a lower rpm when throttled down. So I think they have taken care of some of his concern on some models.
I posted this further up the page so pardon the repeat. My JD manual (5045E) says to turn the steering all the way to lock so that the relief valve opens and hold it their for no more then three minutes to let the power steering pump circulate all the fluid through the pump and relif valve which will warm up the fluid. That's easy to do and gives the engine a couple more minutes at high idle to warm through all the parts. You can also work your loader up and down to give the pump more to do under light load and swapping the cold fluid in the pistons and lines for fresh & warm from the pump.Warming my tractor in winter months is usually not my problem. My hydraulics are my issue. My tractor starts and runs fine but my hydraulic pump will squeal if it has not had a chance to warm up or cycle warm fluid through it for a time. I usually have to go very slow for the first ten minutes or longer. I have found a magnetic heater that works somewhat well but being the pump is aluminum can only get it so close. I do have a new tractor this year. Any suggestions on how to help heat the hydraulics? I don't want any problems.
I had issues starting my tractor not long ago and gave my service department a call and he said to put the throttle 1/4 open, heat the glow plugs for 30 seconds and crank it. When started establish 1200 rpm throttle then turn on PTO and put loader into float (this cycles the hydraulic fluid through everything and warms it up fast) then go have coffee for half hour and I'm good to go. This was at -30C (about -24F)
So once you start your tractor in cold weather it is okay to increase the idle up right after to the range you suggested. I let it run 10 mins or so on lowest idle then increase rpms up where you suggested for another while so it can warm up.
My kubota B3200 is hydrostatic so it warms up the fluid pretty quick. Cycling the loader valve several times is a good idea before you put a load on it. Don't do it at high RPM I've seen problems with Hydraulic systems at work because water in the system can freeze & lock valves ect & cause a hose to blow. Synthetic fluids also help because they maintain their flow properties/viscosity better in cold temperatures than conventional fluids. I would still change fluids according to MFR recommendations even if using a synthetic. Hydraulic fluid has a long life anyway.I posted this further up the page so pardon the repeat. My JD manual (5045E) says to turn the steering all the way to lock so that the relief valve opens and hold it their for no more then three minutes to let the power steering pump circulate all the fluid through the pump and relif valve which will warm up the fluid. That's easy to do and gives the engine a couple more minutes at high idle to warm through all the parts. You can also work your loader up and down to give the pump more to do under light load and swapping the cold fluid in the pistons and lines for fresh & warm from the pump.
You want the temperature just below freeing to avoid condensation.![]()
My block heater is plugged in a thermostat controlled outlet (turns on when it hits 0) so for the last month it has been on steady and it was still a struggle to start, that's why I made the call.Makes a whole lot more sense to plug in the block heater instead.
