Starting problem - Jinma 284
/ Starting problem - Jinma 284 #1
oviv
Hi,
My Jinma 284 tractor was A-1 yesterday.
Today, I've done a 250 hours maintenance (changing oil & filter; gear oil, prestone, injector oil & air filter cleaning).
After that, when I try to start the tractor does start anymore and it does't crank.
Here is a short clip of what it done : http://w4.uqo.ca/ortho/unstart.mov
Anybody has an idea of what happens ???
Thank you for help
Al
PS : in this picture (http://w4.uqo.ca/ortho/inj.jpg), after putting oil in bolt hole (see bolt cap number 1 on picture), I pull out the gauge (number 2 on picture) and diesel start to squirt... I put it back right through to its place, but does it has a link with the starting problem?
/ Starting problem - Jinma 284 #2
Diesel from the injection pump dipstick hole suggests that you didn't drain the pump sump before refilling with clean oil. The starting issue suggests that somehow in your maintenance you affected a battery/starter cable or wire. I'd start at the battery, remove both cables, clean posts and connectors, then do the same thing to the other ends of the cables (emphasis on cleaning the frame under the ground cable). Then make sure the keyswitch to clutch interlock to starter solenoid are all clean and tight.
//greg//
Thank you Greg,
but how do you drain the pump sump ? I just see the hole (the one with a bolt with cap) for filling oil...
I will try your suggestions and come back.
Thanx again
Al
You were right with the battery/starter cleaning issue.
The problem was resolve by checking, cleaning and tighting all electric contact from battery to starter, including clutch keyswitch.
Thankk you very much for your help.
Have a good week
Al
/ Starting problem - Jinma 284 #5
Looking straight on at the fuel delivery system, that mushroom looking thing is top right is the fill vent. To the right and below that (side right) are two hex head bolts. The bottom one is the drain, the middle one is the fill level. On some models the drain is actually underneath, but mine were the bottom bolt on the right vertical face. Remove fill vent, prepare to catch old oil, open drain, drain. When empty, replace drain plug, remove middle bolt (again, right side vertical). Fill from top until you see fresh oil spilling out the side hole. Replace side bolt, replace fill/vent cap.
//greg//
Got it! Thank you !
Badly, I finish my maintenance by changing the fuel filter. I put off the old fuel filter and place a new one.
After that, I start the tractor and it run normally but just only for 20-30 seconds. It stop, like being out of fuel (tank is half full). I try to start again and again, but it crank without starting.
This problem happen just after the replacement of fuel filter. After unsrew the old fuel filter, it was full of fuel; but the new one was clean and dry. Did the problem of starting could be of air in filter that came in fuel line? If so, do you an idea of how to manage this problem?
Thank you again for your help
Al
/ Starting problem - Jinma 284 #7
Fill the filter with fuel and reinstall then on the injection pump there should be a primer. Pump it and try to restart.
Chris
/ Starting problem - Jinma 284 #8
Yup, you've air-locked your high pressure side. Start with a filter canister full of fuel. Loosen the rubber hose that goes between the filter and the pump (loosen at the pump end). This is the low pressure side. Use the hand primer pump (round knurled thing at the right of the pump assembly). It unscrews to unlock and pump, screw back down when you're done. Pump until fuel comes out the loosened hose fitting. Tighten fitting. Follow the steel fuel lines up to the top, note that they tighten with a hex collar. This is the high pressure side. Loosen the hex collars about 3/4 turn, crank engine. Air (and light fuel spray) will come out first, soon changing to all fuel. As each line starts spurting raw fuel, tighten its hex collar. Now your tractor should start.
//greg//
Well...
Thanx Greg, but this procedure will be challenging for my knowledge and experience...
Anyway, I don't have any choice and I will give a try and see what happens...
Thanx again
Al
/ Starting problem - Jinma 284 #10
Its not that hard. Just follow the system. Fuel comes from the tank to the pump, through the filter, back to the pump, then to the injectors.
Chris
Ok. I think I'm too much visual to do that job and let me explain what I understand with five pictures.
First picture show fuel tank (top right) that go to fuel pump. There is a small transparent bottle with a valve faucet, do I need to do something with this?
Second, it is the bottom of the fuel pump (Passing there, I note the drain bolt for the injector oil) . At this picture, there is a bolt connecting the hose from fuel tank : do I need to slack this bolt there to purge the air in fuel line?
Third, the picture show a hose that goes in fuel filter and then return back in injector pump (I think so). In this picture, there is a lot of bolts, and I'm not sure if there is something to do there with bleeding air in fuel line....
Fourth, at extrem left (front side), there is a hose that come from the pump (injector pump?) and goes to cylinder (in serial, one after one). Also, there is three metal slot with screw that go in each cylinder. Is there those three screw at thois place (near the injector pump) that I must unsrew (3/4 turn) to bleed the air?
Five, at the botton left, it is the hose that come from pump (or injector pump) and finish its course in fuel tank, AND also, there is same type of screw as the last picture, but near the cylinder. Questions here are : do I unsrew (3/4 turn) those three screws from the injector pump? Do I unsrew other bolt (from the pump) ?
I hope picture and question are clear enough. If I am not correct, you can refered to any picture number.
Thank you for help, it is very appreciated.
Al
finally, I bleed the air in fuel line....
thanks all!
Al
/ Starting problem - Jinma 284 #13
Glad you got it going.
Chris
2001 VIBROMAX W1106PD ROLLER (A66091)
2001 VIBROMAX...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
FUEL TANK & HAND PUMP (A64278)
FUEL TANK & HAND...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
HAY KING PASTURE AERATOR (A64278)
HAY KING PASTURE...
