Starting problem gt2544
/ Starting problem gt2544 #1
tracyguy
tracy,iowa
GT 2544
Mowed with my tractor and shut it off to clean and then would not start. Starter not turning/engaging but there is power to the starter. There's a clicking sound from under the dash coming from a relay, is this the problem?
/ Starting problem gt2544 #2
Check the battery with a load tester. Look for loose wires.
Sounds like the relay is engaging just not enough power getting to the solenoid.
/ Starting problem gt2544 #4
You can take a jumper cable and connect one end on the positive battery post. Touch the other end to the large starter terminal. This will bypass the ignition switch and relay and tell you if the starter works.
Bob B.
/ Starting problem gt2544 #5
Update, please.
What was the cause?
John Deere 6330 (A64911)
John Deere 6330...
CAT 930 GP Bucket (A68134)
CAT 930 GP Bucket...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
(2) Goodyear 12.5/80-18 Tires & Rims (A64911)
(2) Goodyear...
NILFSK PRESSURE  WAHSER (A68842)
NILFSK PRESSURE...
