Starting from scratch; basic advice needed
/ Starting from scratch; basic advice needed #21
soundguy, I like the sound of what you're suggesting (4wd 50hp, etc.). Size sounds practical and affordable unless I am unaware of some safety or ease of use gained from getting bigger/more powerful equipment.
50 hp is doable.. for sure 60 or 70 would make it easier. As FWJ points out.. the bigger you go the more $$ it is.. and the more $$ the implements are, as they are bigger. For instance.. a 10' mower on a 70hp tractor is a cheaper rig than a 15' mower on a 95 hp tractor...
soundguy
/ Starting from scratch; basic advice needed #22
Flusher.. I'm envious of all your nifty hay equipment! ;)
soundguy
And I'm envious of those really neat old Fords in your collection, especially that 500 series beauty with the offset engine. I'd really like to find one of those babies.
/ Starting from scratch; basic advice needed #23
I've been looking for one of those babies for years.. and to think a couple months ago.. i almost squandered my money on another trike.. a 740.. luckilly I waited and pulled the trgger instead onthe 541!
soundguy
soundguy
Soundguy, when you say easier, what exactly do you mean? Faster (bigger jobs get done more quickly)? Easier to operate somehow (more powerful steering, easier turning...)?
(may seem like an idiotic question, but your answer will help me a lot)
/ Starting from scratch; basic advice needed #25
I think one of the areas where SouNdguy suggests bigger as being easier would be in volume of work done in a given time. But.....there's always that but......Bigger means less manueverable in wooded conditions. The description of your farm doesn't sound a lot different than my old place. And that is why I farmed with what some would consider relatively small tractors (or at the very least, mid-sized...) BIG big can have it's down side.
JMHO, I'd be thinking 50 to 60 hp, loader, MFWD IF it can be had reasonable.....
/ Starting from scratch; basic advice needed #26
My tractor's in the "teensy" category, and though I'm still discovering other uses for it, I got it mainly for snow removal. My driveway's gravel, with a steep section, and although it tends to be a bit light on the front going uphill (I keep the backhoe on for traction), it does a great job. I just pack the first few storms down to have a firm base. Having the blower means no snow piles to remove later, no restrictions in visibility at the top of the hill, and only one pass to remove snow.
But, it sounds like those may be non-issues for you.... and a plow would certainly be easier on the budget!
Listen to the "old timers" on this forum- their advice is like money in the bank!
  • blower 12:1:08.jpg
    blower 12:1:08.jpg
/ Starting from scratch; basic advice needed #27
Yep.. Farmwithjunk naile dit. For me.. easier is less time.. since time is a problem for me with 2 jobs and a farm.
As he also pointed out.. having a huge tractor and a big mower has it's own set of problems.. turning radius and clearance for passes in narrow areas becomes a real issue.
A 50-60 hp tractor and an 8' mower can squeeze thru 7-8' openings however..
soundguy
/ Starting from scratch; basic advice needed #28
SarahM; have you considered putting together a business plan before you venture into the purchase of equipment and wish to start farming??
That might indicate the type of equipment you require to produce a salable product and if the economics are there to support a Farm lifestyle.:D
Otherwise you may end up working at an outside job to support the Hobby you call a Farm. That sorta leaves you at the tail end of both prospects. You can't devote proper time to the Farm and you don't have the options to make the best of the Job! The cost of the equipment kills your budget and there is no spare time for the odd day off.:D You end up being neither a farmer or a career person.:confused:
Now this advice is coming from an old fellow who last spent time on a real farm about 50 + years ago but plays around on 68 acres of which 10 or so are cultivated that he calls "The Play Farm". :D These acres don't make no money but may be considered "The Old Man's Golf Course" in lieu of actually playing golf!:D
Farming and making enough money to support the Farming lifestyle ain't easy!:D
/ Starting from scratch; basic advice needed #29
I like the idea of something in the 50 hp range. That is about as much horsepower as you can get and still get a Hydrostatic transmission. Transmission type is a hotly debated issue here but for ease of use and your hilly terrain it would be my choice. A tractor of that size will do what you are considering and still be maneuverable.
The one thing you mention that I would research further is making hay. Hay equipment is expensive, generally requires a larger tractor for baling and haying is labor intensive. Having someone else do your baling for shares could well be more cost effective.
Good luck,
MarkV
/ Starting from scratch; basic advice needed #30
That's one reason a 2-tractor combo sometimes works good.. older cheap 2wd gear tractor for the stuff like hay.. and a smaller 4wd loader hst trans tractor for the utility work.
soundguy
/ Starting from scratch; basic advice needed #31
Congrats on the decision to keep and work the farm.
I would suggest that you not make hay on your farm. If you "put a pencil to it" you might very well find that it makes more sense to purchase hay instead. Store your hay properly in a shelter to minimize waste. Learn about efficient hay feeding methods (cone feeders work well for example, but you do have to move them or see that it does not get too muddy around them). Learn about rotational grazing and forage stockpiling methods to minimize the amount of hay required in your operation.
If you decide to not make hay you will not need to purchase/maintain/store a bunch of expensive hay implements. Also, you could possibly then consider a less expensive 50 -60 HP tractor instead of a 70 - 90 HP model.
I agree with others who suggested that you go with a 4wd tractor and front-end loader.
Good luck!
Good luck,
MarkV
I think I'm in agreement with you (and others--thanks everyone!) on both of these suggestions.
Actually, my next step will be to visit a few dealerships to see what (if anything) I can handle in the way of tractors and attachments.
Egon, I've thought about all of this. The farm has been in my family for 25 years, so it's already being farmed. If I do not buy any equipment, but continue to farm it on shares (am I saying that right? what I mean is splitting profits with nearby farmers who actually do the work, but on our land...), it will turn a small profit. There isn't much overhead.
I mentioned in a previous post (to Farmwithjunk, I think), that I had in mind something around 20K-- reason being it would need to pay itself off with whatever work I'm able to do with it.
/ Starting from scratch; basic advice needed #34
I applaud your determination and it sounds like your attacking this the right way, keep what's working paying the bills and "break into" the rest as you can.
BTW, I'm just down HWY 50 from you, near Loogootee.
One thing I'll mention on tractor choice for the amount of land you have is 50 ish HP sounds right for now but if you think you may want to take over more of the farming yourself in the future look at brands that also make bigger tractors. Kubota makes a fine tractor but their biggest is a 53 hp utility tractor. If you decide to grow there isn't a bigger one to be had and you may not get the same money on trade for it from a different dealer. I second FWJ on Stone and Stemle, they have treated me very well and have a good reputation.
I buy from Troy Pride [Phone (812) 254-4005 or Toll Free (800) 255-4960]
out of their Washington store. It's a little further for you but he has really taken care of me. He once "ate" the cost of a transaxle rebuild (~ $1800) on a 14 year old used garden tractor that I bought from him 6 months earlier. :D Now that's customer service!
I don't know much about commercial farming but I do know a few folks over this way, if you have a question I'll be happy to ask them. Maybe they can point you in the right direction!
Good luck!
/ Starting from scratch; basic advice needed #35
The important part is the dollar numbers and do not forget about running costs, repairs and replacement.
Haying was mentioned I believe. Figure these costs carefully and also take into account bale handling and the number of people required for the operations you intend.
The choice of which equipment to get is most likely the least of your decisions. Successful farming requires very close contact with the fluctuating markets and production costs. Figure those out and you will be successful.:D
Again Note: I'm not a Farmer! Don't even pretend to be one!
/ Starting from scratch; basic advice needed #36
Uhmmm....I beg to differ. I used my 85 HP Kubota utility tractor just last night, Kubota makes utility tractors from 50 HP to 125 HP. Kubota's are also well known for their value. :)
/ Starting from scratch; basic advice needed #37
I stand humbly corrected:eek: Kubota M series does go up to 103HP.
Kubota's do hold their value well, was just pointing out that if size offerings forced a color switch the trade would not be as favorable as staying the same color.
Seen plenty of bota's around barns here in Indiana but never one in the field..In these parts anything under 150HP is considered down right "cute" and my 2210 is a riding lawnmower!
/ Starting from scratch; basic advice needed #38
Actually Kubota goes up to 135hp with the M135x
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2023 HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A62129)
2023 HANGCHA...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
John Deere Hood Guard (A63116)
John Deere Hood...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
