Starting a Cold Deisel ??
/ Starting a Cold Deisel ?? #21
I take it the machine will be out in the woods not close to electricity.
D7E's picture says it all. :thumbsup::thumbsup:
Tried and true method that has been used many times.
Maybe add some tarps to the top and backside.
Try and park where the machine is accessible.
/ Starting a Cold Deisel ?? #22
WD40 works almost as well as either without the inherent danger of engine damage. In moderately cold temps its effective and provides a little cylinder lube at the same time.
I don't think washing the cylinders of lubricant is the major hazard of using ether in a diesel engine. Obviously having dry cylinder walls doesn't help anything, but I don't think that is what breaks stuff, at least in the smaller diesels I'm familiar with.
/ Starting a Cold Deisel ?? #23
The usual problem with ether is people generally use too much . as said a lot of north american kit comes with ether inject fitted , My TW20 has it and the engine is now at 11'200 hrs , i've had it since 5'800hrs and done nothing to it .
I dont like using it in extreme cold like our -30's as they will start but the oil is so thick i like to warm the engine with a heater if in too remote a location to plug block heater or pan heater in .
Our 300hp 6 cyl's will start with ether but run on 2-4 then 6 as they warm up clattering and billowing smoke, i rather see the oil warm :)
/ Starting a Cold Deisel ?? #24
Back in the 80's there was an extremely cold winter and we took a car from KY with no plug in heater to MN. My wife drove and I flew in a few days later. AAA was no help because most of their vehicles wouldn't start and their waiting list was more than a day long and they cancelled the list and restarted it everyday. When I got there I walked to a Holiday gas station, bought a shallow pan, bag of charcol, and lighter fluid. Got a nice bed of coals going and slid the pan under the engine. In 15 minutes the engine was purring like it was back in KY. The year after I got my F-250 diesel I needed to take it to Chicago and park at a hotel with no way to plug it in. The forecast was for -10F. I put Shell synthetic oil in with 2 new batteries and it started right up. I have never successfully started my Allis Chalmers 5040 below 40 degrees F. without pre heating it. Last winter I got to thinking, the F-250 likes the synthetic oil so much, I wondered how the tractor would like it. I tried it and started it at 30 degrees F. with no problem. I still plug it in when it is below 40 but it was good to know that the synthetic oil helped a lot.
Another thought is to put an aircraft engine preheater on it. Many of these units are self contained and operated off propane with a 12V battery to power the blower. If you google aircraft preheaters you will come up with a good variety of possibilities. Even if you can get your engine started without preheating it, I think everyone would agree that there is less wear and tear on an engine that has been preheated. One number I saw was that one cold start on a light aircraft engine equals 500 hours of wear at cruise power. I think that is overstating it but I think the savings on wear on the engine would definately pay for a preheater.
I don't know how effective it is but when starting a reluctant engine I keep a pretty close eye on how hot the starter is getting. I think the reason for the limit on starter time is so that it doesn't get so hot that the components inside the starter start to melt.
Good Luck.
/ Starting a Cold Deisel ?? #25
Not pertinent to diesels, of course, but your story about your KY car in MN reminds me of another cold weather trick: if you have a running vehicle and are jumping the battery, while the non-starter is charging up, take out its spark plugs and stick them in the exhaust of the running vehicle to warm up, then reinsert and start. ...and, another oldie but goodie when gassers had manual chokes was to shut it down by choking it, which would wash the cylinder walls...starting was a lot easier although a little more wear on the engine (which only meant it started easier, anyway).
/ Starting a Cold Deisel ?? #26
I've seen people floor the throttle after turning off the key at fast idle. Same effect.
I never did myself, I don't like the vision of no cylinder lube and diluted oil.
I think this was more common before multigrade oil, when starting in cold weather was a real challenge.
/ Starting a Cold Deisel ?? #27
My old Yanmar has nothing for cold starting and when I needed to start it, I would pull the cover off the air filter and run wife's electric hair dryer on hot into the air intake to preheat the air. It started great with that, but you do need to be close to electricity.
I found it worked well on my two-cylinder Yanmar to simply heat the head between the cylinders, using a hair dryer. Set the dryer on low, go back in and drink coffee, come out and the head is warm to the touch. The tractor thinks its a warm day, starts easily, little clanking.
I first tried using a sink drain J-bend (heavy plastic, since this is near the battery) to mate the hair dryer to the air filter snorkel tube. I think using the hair dryer to warm the head and coolant as shown here works better.
/ Starting a Cold Deisel ?? #28
I scanned quickly and did not see this brought up yet. Sorry if I missed it.
Back in the '80s I worked in the woods here in northern Maine and we had some brutal cold at times.
The skidders we used were started with either on colder mornings but when temps got way down every one used to preheat the engine blocks with their pickups. They would tap into their heater lines of the trucks and by use of quick connect fittings connect those lines to lines that were put onto the skidder. Hot antifreeze would circulate around and around for about 15 to 20 minutes,or more depending how cold, and when the pickup heater was blowing hot air again it was ready.
Hoses were disconnected and the skidder would start right up. (usually) I don't remember how they were plumbed exactly as it was not my skidder but this was very common here back then. Only thing was, no one liked to heat someone else's skidder as it would mix the antifreeze and people were **** about that. We're talking temps. down to -20 or -25 F. Colder then that most would wait a while for it to warm up a little. Holy cow my feet are cold just typing this!
Good luck. Dan.
/ Starting a Cold Deisel ?? #30
If I didn't have one of these in my pick-up I was out of luck thawing frozen equipment in remote locations. Put an insulating blanket over the engine so warm air doesn't rise, speed your pick-up engine to about 1,600 rpm and place the hose under the blanket. Insulate the hose and it works even better. There are BTUs there to be had. The only negative is lots of condensation but that soon dissipates.
2.5in Exhaust Hose
/ Starting a Cold Deisel ?? #31
Good luck. Dan.
Have seen it done with pioneer oil couplers !
/ Starting a Cold Deisel ?? #32
Really great cold weather stories, we had winter last year but I slept late and missed it. :laughing:
/ Starting a Cold Deisel ?? #33
Something people coming up here to MN from the south driving diesel pickups frequently get caught on is gelled fuel. A person from Peoria came up here to teach a class. He was driving his new Chevy diesel pickup. Ran fine on the way up but when he tried to start his pickup the next morning to come in to teach our class, nothing. One of our mechanics went out and checked his pickup - gelled fuel. We brought his pickup into the plant and warmed it up - started and ran just fine. We then sent him across the street to get a fillup of good old Arctic Blend. He had no starting problems for the next 2 weeks before heading back south. Fortunately his tank had been low enough that there wasn't enough of the straight No. 2 diesel left.
/ Starting a Cold Deisel ?? #34
Jump start the battery to keep it charged between starting attempts. Another option with the hair dryer if you can run it off of your running vehicle is shoot the warm air into the air intake tube, it's like having an intake manifold heater.
/ Starting a Cold Deisel ?? #35
I really liked the trick of circulating warm coolant via quick disconnects...learn something new here, every day.
/ Starting a Cold Deisel ?? #36
I really do like the cold. Not cold and wind but a moon lit cold, still, night is beautiful to me. In the winter 30F is wet and soft.:( -10F is dry and hard. The branches of the spruce and fir we cut would break off as the skidder hauled them to the yard and I didn't have to cut them off with my saw.:thumbsup:
Back then, while staying in logging camps, the generator that ran the camp was shut down at around 21:00. The camps slept 2 or 3 crews. (4-6 men)
You wanted a good snow so you could bank the camp. Then, and only then did the kero stove keep it warm.
Every once and a while, when it was REAL cold, you would wake up to a loud SNAP. Almost like a distant gun shot. It was trees splitting from the cold.
I'll never forget that.
Dan.
/ Starting a Cold Deisel ?? #37
Thought I'd add this.
/ Starting a Cold Deisel ?? #38
Ever been in a hot springs pool when it was -30C?
You got icicles on your hair and the rest of you is deliciously warm under the water and if it's a clear night stars in the sky are just awsome. :thumbsup:
/ Starting a Cold Deisel ?? #39
Good luck. Dan.
I was going to give the same suggestion about tapping into the vehicles hit antifreeze. My dad does it on his logging equipment all the time. They have hoses made up with normal pioneer hydraulic fittings.
/ Starting a Cold Deisel ?? #40
Yeah...but what happens when you get out?
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
Caterpillar M318 Excavator Service Manuals vol. 1 and vol. 2 (A63117)
Caterpillar M318...
2017 Nissan Sentra SR Sedan (A61574)
2017 Nissan Sentra...
iDrive TDS-2010H...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
