Starter woes
/ Starter woes #1
Laser Man
Zionsville Pa.
Kubota Lx3310/Cab purchased 2021new
When I turn the key I hear the solenoid click then nothing I hit the starter with a hammer and it starts.
Tractor is a b7500 Kubota battery is a year old voltage is 12.7 is my starter on the way out?
/ Starter woes #2
Could be. But first check and clean all of the battery cables - especially the ground cable.
Another test is to use jumper cables to first check the solenoid. Attach the jumper cables directly to the battery posts (not the cable clamps). Hook the negative to a bolt on the engine. Touch the positive to the solenoid + (hot) connection to see if the starter turns over. If it does then the problem is the battery cables. If it does not then the solenoid is suspect.
While everything above is hooked up, touch the positive to the starter + (hot) connection. The starter should spin. If not then the starter is going. If it does then the solenoid is likely the problem. The solenoid "click" should be it engaging the starter gear but one can't be sure.
Hitting with the hammer may loosen any corrosion in the starter but the shock may cause a poor connection to be able to conduct enough electricity to allow the starter to function.
Anyway, try these tests and report back. Good luck.
/ Starter woes #3
Here is my WAG: either the contacts on the starter solenoid are pitted/dirty and making poor contact or the contacts on the armature of the starter are pitted/dirty and are not making contact with the brushes. Either fix is fairly simple once you determine which it is. Either repair/replace the solenoid or clean the armature and probably replace the brushes while you are in there. The hammer is just jarring it enough to nake contact. I have done that many times:thumbsup:
/ Starter woes
Thank you all very much I on my way to try everything now.
/ Starter woes #5
+1 on battery ground cable. I was having problems with starting and I found the battery ground cable connection was bad - even though everything looked good and tight. There was no obvious corrosion, but when I took it apart for cleaning, the rust/corrosion was there.
/ Starter woes
Okay back in the game here's what I did removed both battery cables and cleaned them and the battery
I also removed the frame connection cleaned the frame and terminal now it starts
Thanks again everybody
Landhonor No Till Seed Drill (A62679)
Landhonor No Till...
2022 EZ-GO ELITE...
2018 Ford F-150 Crew Cab Pickup Truck (A64556)
2018 Ford F-150...
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
