Fuddyduddy1952
Super Member
- Joined
- Aug 10, 2022
- Messages
- 9,816
- Tractor
- john deere
You can troubleshoot it in 5 minutes.
1) voltmeter across battery. Voltage is ______
2) now while cranking, voltage is ________
3) meter leads black negative on starter case, red positive on large starter lug. Voltage is _______.
#2 should equal #3 measurement...within 0.1 volts (close). If not troubleshoot: Meter black negative on battery negative, meter red + on starter case & crank on it. Should be zero volts. If not, bad cable or bad ground.
Same with positive side. Meter black negative on battery negative and work back from starter. Cranking voltage should be same on both sides of solenoid. If not...replace.
