Start engine with PTO engaged
/ Start engine with PTO engaged #11
First, you have a two stage clutch. There will be a first stop, which only disengages the drivetrain. Then it goes further, which disengages the PTO. This so one can change gears without stopping the PTO. I know you say you have pushed it down all the way, but it may have only been to the first stop, this has happened before.
Otherwise, as said above, the clutch needs to be adjusted. It is straightforward and is in your manual.
Second, as I found out, the only safety start inhibit is the clutch switch, there are no seat switches or PTO switches. Can be good or bad depending on your point of view. Although a switch that prevents starting with the PTO engaged seems like a good idea to me.
Cool, thanks guys. I will be adjusting the clutch before next time running it. I didnt know about those other switches not existing. I dont know where (or why) I thought mine had em. The safety switch is a call each owner must choose. I dont mind it starting with the PTO on, but thanks to this site, it showed me a bigger potential problem with my clutch.
So do all of ya'lls tractor start with the PTO engaged?
/ Start engine with PTO engaged #13
Nope. Will not start with PTO switch engaged. But My tractor uses an electric/hydraulic PTO engagement. There is just a rocker switch on the dash to engage the PTO and a Auto/manual PTO switch.
/ Start engine with PTO engaged #14
Clutch has to be in to start. So with engine not running, I push clutch in, engage the PTO, then start the engine. The engine starts and the PTO attachment starts spinning. In this case, a finish mower. When done mowing, I can disengage the PTO no problem without any grinding with the clutch in and engine running. The only grinding occurs with engine running at slow idle, clutch in, and try to engage PTO.
So the finish mower starts spinning before you let the clutch out?
What happens when mowing and you push the clutch all the way down as hard as possible, past the first detent? Does the mower stop spinning?
/ Start engine with PTO engaged #15
I bought my CK 25 used. It is NOT Hst. When I put finish mower on it and tried to engage the PTO, it would grind really bad. I was completely stopped, engine at slow idle and pushed clutch in for several seconds before trying to engage PTO. One day, my dad was on tractor and started it with the PTO engaged and it stared fine. From that point on, if we want to run the PTO, we engage it first, then start the engine and so far works like a champ.
Any concerns doing it this way? I'm assuming the original owner disconnected the safety switch. Should I keep it this way?
Serious , kidding or bored and trying to get everybody all worked up ?
/ Start engine with PTO engaged #16
I'm giving OP the "benefit of the doubt", I believe it's his first tractor, joined in October.
Hopefully the PTO clutch not disengaging is something as easy as adjusting the linkage and not the clutch itself.
People "adapting" rather than fixing is very common (as you/I probably see everyday). Op seems to be asking if this is the right choice. Granted, for you and I, it's easy to imagine what the "concerns" are, but for the OP maybe not, as his adaptation has worked like a champ so far.
/ Start engine with PTO engaged #17
X
Wrecks , accidents , incidents, maiming and death almost always involve such Jerry Rigged solutions.
/ Start engine with PTO engaged #18
I have a question on this issue.
I've read multiple times about a stuck clutch.
On a 2 stage clutch like the OP has, can the PTO clutch get stuck and the main clutch still work and cause an issue like this ??
I have never had a 2 stage clutch apart, so I'm not exactly sure how the clutch discs are separated.
If the main clutch can be disengaged while the PTO is still running the clutch discs must run on separate splines where one disc could stick and not the other.
Is that correct ?
Absolutely not playing any games. This is my first tractor and have better things to do than get everybody worked up. The finish mower starts spinning when the engine starts. If I push clutch all the way in, it still spins. The FM wont stop unless I disengage the PTO. As I mentioned, I get the whole safety thing about it, but come on, wrecks, maiming and death???? I have no ulterior motive here my friend, just trying to figure it out.
/ Start engine with PTO engaged #20
-------- The finish mower starts spinning when the engine starts. If I push clutch all the way in, it still spins. The FM wont stop unless I disengage the PTO.-----------
You are not pushing the clutch in far enough or it is way out of adjustment.
40 (A52708)
40 (A52708)
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
17601CFL (A59228)
17601CFL (A59228)
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2025 MACK GR64F DUMP TRUCK (A59823)
2025 MACK GR64F...
