Start a Kubota X900 other than in neutral?
   / Start a Kubota X900 other than in neutral? #1
KennyR
Big Rock, IL
Kubota 2380
Is there any way to modify a Kubota RTV-X900 so it can be started while in gear while simultaneously depressing the brake? I know that is designed as a safety feature, but I previously had a Kawasaki Mule 400 which had the ability to start in neutral as well as while in gear as long as you fully depressed the brake. I liked not having to shift each time when starting and stopping so often on a number of projects while working on my acreage.
Thanks for any feedback.
   / Start a Kubota X900 other than in neutral? #2
On my older 900 I unplugged the neutral switch at the tranny and added a jumper wire to it.
Ovrszd,
Thanks for the suggestion. Just to clarify, did you add the jumper wire from the starter to the neutral switch?
   / Start a Kubota X900 other than in neutral? #4
Ovrszd,
I think I simply jumped the terminal that plugged onto the trans switch. I'll look today and let you know.
Deere 35P (A53317)
Deere 35P (A53317)
Kawasaki NR (A50324)
2021 PJ 16 T/A DUMP TRAILER (A55745)
2021 PJ 16 T/A...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
