Start a Kubota X900 other than in neutral?
   / Start a Kubota X900 other than in neutral? #1
KennyR
Member
Big Rock, IL
Kubota 2380
Is there any way to modify a Kubota RTV-X900 so it can be started while in gear while simultaneously depressing the brake? I know that is designed as a safety feature, but I previously had a Kawasaki Mule 400 which had the ability to start in neutral as well as while in gear as long as you fully depressed the brake. I liked not having to shift each time when starting and stopping so often on a number of projects while working on my acreage.
Thanks for any feedback.
   / Start a Kubota X900 other than in neutral? #2
On my older 900 I unplugged the neutral switch at the tranny and added a jumper wire to it.
Ovrszd,
Thanks for the suggestion. Just to clarify, did you add the jumper wire from the starter to the neutral switch?
   / Start a Kubota X900 other than in neutral? #4
Ovrszd,
I think I simply jumped the terminal that plugged onto the trans switch. I'll look today and let you know.
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
KUBOTA SLV95-2S TRACK LOADER (A55745)
KUBOTA SLV95-2S...
2001 Nissan Pathfinder SE SUV (A55853)
2001 Nissan...
