Start a Kubota X900 other than in neutral?
   / Start a Kubota X900 other than in neutral? #1
KennyR
Big Rock, IL
Kubota 2380
Is there any way to modify a Kubota RTV-X900 so it can be started while in gear while simultaneously depressing the brake? I know that is designed as a safety feature, but I previously had a Kawasaki Mule 400 which had the ability to start in neutral as well as while in gear as long as you fully depressed the brake. I liked not having to shift each time when starting and stopping so often on a number of projects while working on my acreage.
Thanks for any feedback.
   / Start a Kubota X900 other than in neutral? #2
On my older 900 I unplugged the neutral switch at the tranny and added a jumper wire to it.
Ovrszd,
Thanks for the suggestion. Just to clarify, did you add the jumper wire from the starter to the neutral switch?
   / Start a Kubota X900 other than in neutral? #4
Ovrszd,
I think I simply jumped the terminal that plugged onto the trans switch. I'll look today and let you know.
2003 Big Tex 10PI...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
MILLERMATIC 251 W/LEADS (A55745)
MILLERMATIC 251...
198367 (A51243)
198367 (A51243)
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2010 GLOBAL TRI AXLE HAUL TRAILER (A55745)
2010 GLOBAL TRI...
