Stalled tractor bush hogging
/ Stalled tractor bush hogging #1
caleb90
ih b414
Was bush hogging today ended stalling the tractor out 3 times. Ran blades into mounds of dirt and never broke the shear pin, assuming because it never hit hard. Using plane 1/2 bolts with no head markings, same ones ive used and broke before. That being said how durable are these electric over hydraulic pto clutches? Checked the fluid and it dosnt smell burnt or like clutch material. Whats the odds i hurt somthing
/ Stalled tractor bush hogging #2
Probably nothing. The shear bolts should be engineered to shear before damage to the clutch packs.
Try not top make a habit out of it and shoot the ground hogs if they are making the dirt mounds. Those miserable oversized rats do the world zero good and may cost you dearly if it happens continually.
/ Stalled tractor bush hogging #3
I know a fellow down here that more or less leveled his property by scalping with a bush hog mower LOL, although he had a slip clutch on his mower and he is still using it today.
/ Stalled tractor bush hogging #4
Bush hogging does have a leveling effect over time
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61306)
2020 Takeuchi...
