etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,409
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
A few months ago I bought a Yanmar YM2310 tractor. It is the most modern tractor I own. It has the Bulldog 285 FEL on it and the tractor came with clamp on forks. I already have a forklift and so am used to forks that stay where I put them. The clamp on forks tend to move, to swivel, so that they are no longer perpendicular to the leading edge of the bucket. This is a problem. The bucket is fairly lightweight so I'm gonna weld on a couple of 3/16 inch thick stiffening plates in the general area where the forks go. This way the forks can be adjusted width wise. But the swiveling problem will still exist. I am considering welding some lengths of 1/2 inch thick square steel stock to the stiffening plates to trap the forks in various positions. This will limit the fork positions to just a few set widths but I don't think that will matter if the positions are chosen carefully with a little forethought. But then there will be 1/2 inch thick strips of steel welded to the bottom of the bucket which may interfere with other bucket operations. After all, I have never seen a bucket with strips welded to it like I described. So, anybody got any better ideas? At this time in my life I am having lots of emotional stress. This is affecting my thinking. Stuff that would normally be obvious to me is not. I need some distractions to help relax my mind. Getting the forks securely on my tractor will help.
Thanks,
Eric
Thanks,
Eric
