square baler trouble shooting
   / square baler trouble shooting
I have the original operator's manual, has some content and trouble shooting, but most of it is based off a new machine versus a neglected one. Still good reference. Hope you can get it moving, once it's turning it is much easier to identify anything else it needs.
Can you send me a PDF of the manual?
   / square baler trouble shooting #52
I am just getting back to this project. I am hoping to get it operating for winter so I can rebale round bales to feed my milk cows 1 at a time.
I don't know your layout but your statement has me curious. There isn't any place close to the cows to feed off the round bale without going through all the extra time and expense to rebale just to feed it out. My barn isn't set up for round bales by any means but I feed them with no issue and they are baleage. They are all fed out by hand. Unravel round bale with a fork and put in the manger. 35 head, 3 different areas, 6 different bales, and soon adding another pen which will add 2 more bales to the labor.
I do not have housing for winter feeding. I am planning on continuing rotating them through the winter until ground is wet. The square bales would be fed on there front polywire line everyday. Since I am only feeding 2 or 3 cows so I think unrolling would be to much at a time.
   / square baler trouble shooting #54
I have disconnected the swingarm from the plunger and have been soaking around the plunger with PB.. It is very stuck. The baler is hooked to my truck and I hooked the plunger to a 6x4 gator. When I drive the truck I drag the gator. I am scared I am going to bend the plunger if I hook it to a heavier object. I backed off all the adjustment bolts that I could find(Six opposite the pickup side). The shims are all swelled up with rust.
I have not tried hitting the plunger from the back side to see if it would move at all the other way yet.
Any ideas what I should try next?
Can you afford to try another baler? I like a JD336
   / square baler trouble shooting #55
If youre going to hit it use a "battering ram" made from a 4x4 or 6x6. Give it a good bump.
   / square baler trouble shooting #56
If you run a chain from the plunger out the back of the bale chamber to a handyman jack/jackall you can place a heavy beam across the chamber for the base of the jack to rest and hook the chain to the jack so the jack is pulling the plunger horizontally out the back of the machine. You will need to anchor the other end of the jack so it stays inline with the pulling force. You can slowly apply strain with the jack. Of course you have to know what you are doing since there is a reason they are called suicide jacks.
I did this on an parts #9 years ago and it worked. Trying to pull with wheeled vehicles doesn't give the same effect. If it's really bad you might have a lost cause...
I gave up on square bales, sold the baler. One old barn is still set up for them but I tear rolls apart by hand, still a lot easier than messing with another baler.
I am going to remove the hood on top of the baler. There are a couple plates underneath the hood that span across the baler and I can take those off too for access to the top of the plunger.
I'll cut the plunger in half with a angle grinder if I have to but not ready for that yet..
2007 Mercedes Benz S550 (A56859)
2007 Mercedes Benz...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2023 John Deere 333G for Parts (A56435)
2023 John Deere...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
