Spring Cleaning
/ Spring Cleaning #1
jfh28
Platinum Member
Poconos, PA
Power Trac 2425
With the snow and ice finally melted away I have been able to get into the woods to do a little spring cleaning of trees that have fallen or are about to fall. Had one that had the potential of hitting the house so I needed to deal with it before the big spring storms did it for me. I carefully looked at the canopy........studied the way it was leaning......calculated where I wanted it to fall......planned my escape path.......cut the absolute perfect notch.......and then a beautiful dead on fell cut.........and the darn thing still fell 180 degrees opposite of where I wanted it to go! Fortunately I had the PT to clean up the mess from my expertise! Jack
/ Spring Cleaning #2
Sound like your technique is spot on, you just have to remember which way you really want it to go.
Looks like you have your outdoor bbq fuel for the year. :thumbsup:
/ Spring Cleaning #3
Yeah, I had one of those. It gave me a renewed appreciate for "intrinsic tension" in trees.
Bottom line, it is easy to do in a forest where things only grow straight up, but out in the open...
I'm glad it didn't hit the house.
All the best,
Peter
/ Spring Cleaning #4
All the best,
Peter
Would you explain that please, Intrinsic Tension.
/ Spring Cleaning #5
That's the moment you make the cut, but think maybe you shouldn't have, but keep going anyway....
/ Spring Cleaning #7
"Intrinsic tension:" wood fiber strains distributed differentially within the trunk. Often caused by growth habits, and not necessarily related to canopy mass distribution or moments. Can cause trees to fall away from their center of mass, because the initial cuts in the trunk relieve some tension, but not others, causing contraction and relaxation of only a portion of the trunk that pulls the trunk and tree. Can also cause trunk splitting on trees being topped, and is the not infrequent cause of death off arborists.
Be safe out there.
All the best,
Peter
/ Spring Cleaning #8
Oh. That Intrinsic Tension.... thanks. :)
Yes, tree felling is terribly dangerous. I've been heating our home with wood for about 5 years now. Each year I take down 50-60 telephone pole size trees, along with a lot of large storm damaged cherry trees. Each one is a bit different. None act exactly the same way. Trees on hillsides are squirrelly. The tend to grow away from the slope and then reach for the sun. Standing on a slope trying to eyeball which way a tree is going to fall when you cut its bent trunk is a lesson. The slope tends to make your judgment off a few degrees VS on flat land. And if a wind comes up, all bets are off. Felling trees in a woods VS on the edge of a clearing is the thing I dislike the most. Snags and hang ups are a major concern. Now that I have a few clearings to drop the trees into, its much safer. I could go on and on. Be very careful in the woods. ;)
/ Spring Cleaning #9
But did it fall on the house or damage anything?
I can almost bet that you did not use a wedge. The wedge will provide a more positive control.
/ Spring Cleaning
actually I did use a wedge but maybe I didn't have in in far enough as it popped out when it fell.......thinking back over it the only thing I can think of that I may have been off on was I didn't create the hinge up high enough. No damage to anything......but since it fell opposite I couldn't use the pt to drag it out as planned and instead had to cut it into lengths and then hand carry them to the drive which was not fun.....kind of like rubbing salt in the wound.........Jack
2026 Electric Tricycle (A64194)
2026 Electric...
2014 Jeep Patriot SUV (A64557)
2014 Jeep Patriot...
2018 CHEVROLET EXPRESS 3500 4X2 S/A 12FT  BOX TRUCK (A67148)
2018 CHEVROLET...
96in Forks (A64553)
96in Forks (A64553)
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
