sprayer question
/ sprayer question #1
dixie306
NW GA
JD 4500
I've got it on my mind to make a 25 to 40 gallon 12v boom sprayer, has anyone ever converted a wand type spot sprayer into a boom type sprayer or would the pump be too small? I have a carry all I can mount the tank on and wiring it up isn't a problem, but I don't know about the pumps for them, any ideas?
/ sprayer question #2
i have converted one to a boomless type, it seems to work good as long as there is no wind at all.
/ sprayer question #3
I did that exact thing I used 4 standard nozzles on about a 7 foot boom. It is on a 25 gallon wand sprayer setup with a 2gpm pump. It used to maintain about 20 psi now it's lower, the cheap guage quit on me so I don't know exactly how low but it still gets good coverage. I think I would use a couple of those boomless sprayer nozzles instead of building a long boom if i did it again. I was worried about drift and wanted to get the boom as low as possible to the ground and still cover the area. I took many trips up and down the driveway experimenting with different nozzles and boom heights.
I want to upgrade the pump to a 3gpm pump sometime but it works rfor now.
Here are somer pictures of my setup.
/ sprayer question #4
I'm working on that now. My brother came up with some 1" square tubing and angle iron. I bought everything else from TSC. They have special clips made for 1" tubing that the nozzles will fit into. Bought a small pack of 1/4" hose, a ball valve and some hose clamps. So far have spent about $55.00 but haven't put any of it on my 25 gallon sprayer. Will use three nozzles.
/ sprayer question #5
Most of the 25 gallon spot sprayers have a pump large enough to handle a small boom. Most of the pumps are rated in GPM at a given pressure. Most nozzels are also rated in GPM at a particular PSI so you know how fast to spray for a given coverage. If you can get pump and nozzel specs, you can put together the right combination. I think mine is 2.1 GPM at 40 PSI. I started out with a 80" coverage 2 nozzel boom and had no problem maintaining 40 PSI at the boom and was still dumping liquid back to the tank. I calculated that I could add another nozzel for 120" coverage, and still maintain 40 PSI with no excess being returned to the tank. This works great for me.
I was going to build my own originally, but after looking up all the parts, I found it pretty hard to beat the cost for a 25 gallon spot sprayer and a basic 2 nozzel boom kit($47?) from Agri-supply. The original manufacturer was Fimco, and I was able to order a matching additional nozzel and "T" from them directly when I upgraded to a three nozzel boom. I built a tow behind cart for it out of 1" box tube and two wheelbarrow wheels.
/ sprayer question #6
I built this sprayer that I use on the back of my garden tractor. I can drop this tank on a quick attach bracket and be ready to go in 2 minutes. I like it on the back of the tractor because it is easer to use than a trailer. I can spray 60" but my change it to cover more area. I can still use my wand or switch over to the boom. I bought the standard spot spray tank (26 gal) from Northern. The first valve shuts off the boom to use the wand. The "Y" sets the preassure to the nozzles.
/ sprayer question
Thanks for all the info and pics guys. I'm gonna take some of everyones ideas and start on mine this weekend, weather permitting.
/ sprayer question #8
Looks like you have some wild violets in the yard. Have you had any luck trying to kill those things?
/ sprayer question #9
No I haven't had much luck.
2-4-D based stuff knocks them back a little but they come back
The county extension agent said try douling up on the concentration.
/ sprayer question #10
county extension agent better get his stuff together. The label on that herbicide, is law. Him reccommending you double the strength is way beyond his relm.
I would get hold of the herbicide manufacturer and see what they sat to do.
/ sprayer question #11
Well he didn't exactly suggest I not follow the manufacturers instructions, he just asked if I had doubled the concentration. He also asked I had used detergent in the mix(which I did). It was very dry last year when I treated and I plan to treat under better conditions this year. They seemed to be taking over last year but they are a little better this year, so far at least.
/ sprayer question #12
Looks just like a friend's "Weed Wagon" he made, except his garden wagon was painted dark green at the factory.
/ sprayer question #13
I have a FIMCO 55-gallon sprayer with a three section boom, and FIMCO recommends a nozzle height of 17" - 19" above the stuff to be sprayed. They also recommend a pressure of 20 - 30 PSI. However, my sprayer uses a 6-roller pump. I mounted a tennis ball to a piece of rope and hung it to the end of each boom. It sure makes setting boom height on the fly easier.
/ sprayer question #14
Thats a pretty good idea, especially with a tractor like mine that doesn't have position control on the 3ph.
/ sprayer question #15
Thanks Berniep...the tennis ball and rope trick was one idea I had that actually worked well. My 4200 has a simple 3PH position control on the rockshaft control lever; but it doesn't work very well due to the normal slop in all the linkages.
Wind permitting I'll give the sprayer some more work tomorrow.
/ sprayer question #16
I thinik I will jiust spot spray this spring for dandelions and do the whole yard(s) this fall. Supposed to be better to control dandelions and clover in the fall anyway.
/ sprayer question #17
Ok you sprayer guys have gotten me interested in one of these things,,, that and going through 2 agri fab spreaders in 3 years!! the last one I only used twice and the gears are toast! I only spread fertilizer and lime. THe fertilizer is not a problem,,, and I see they have liquid lime, anyone use it?
/ sprayer question #18
Here is a thread I started on my sprayer on MBN a few weeks ago. Might give you some useful ideas...Stan in SW, Mi.
Machine Builders Network
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2017 Freightliner M2 106 Passenger Bus (A66736)
2017 Freightliner...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
