Splitting Wood with Split-Fire Wood Splitter
   / Splitting Wood with Split-Fire Wood Splitter #1
Kubotafan
Nova Scotia, Canada
G1800AWS, B3030HSDCC, L3540HSTCC, JD710A
I have a Split-Fire wood splitter that I use with my LX2610. I had previously used it on a B3030 and L3540 I once had. I would often be splitting word when I had a snowblower on back, and too early to remove it. I made an "A frame" so I could hang it off either my bucket with a center hook or my snow blade with a fabricated hook made from rebar. The hydraulic lines run to the rear remotes, and I only have to unplug two blower hydraulic lines and plug in the splitter to be in business. I can have it hooked up in less than 5 minutes. The blower is off the tractor now and I have a landscape rake on the back, but will try to attach pictures showing my setup. It works well for me.
   / Splitting Wood with Split-Fire Wood Splitter #2
Nice, makes it easy when you've got a little splitting to do and already something on the 3pt.
I have the same 203 splitter here, it stays on it's own tractor while I'm in the splitting season.
   / Splitting Wood with Split-Fire Wood Splitter #3
Pretty clever (y)
gg
My first "A Frame" was made out of 2 x 6 with plywood gussets on both sides of the joints. I used it for several years and was happy with the setup so had the metal one welded up. No regrets and it works good.
2005 MACK GRANITE CV713 DUMP TRUCK (A60430)
2005 MACK GRANITE...
2344 (A60432)
2344 (A60432)
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
