3-Point Hitch Splitter for b2910
/ Splitter for b2910 #1
ChrisC
Looking for a splitter to work with my b2910. I'd really like to get a 3 point hitch model.
I haven't done anything with hydraulics, I do have a FEL. What do I need to know about hooking this up?
Any recommendations for splitters? I will be splitting 3-5 cords a year
/ Splitter for b2910 #2
Most three point splitters should work fine ...... ones with larger cylinders will work slower than smaller cylinders. You will need to run a 'power beyond' loop to the rear of the tractor , the same as you would if you were attaching a backhoe. Plenty of reading here on it if you use the search function.
The more expensive option is to get a PTO powered hydraulic pump to power the splitter, but it would also require it's own hydraulic tank.
/ Splitter for b2910 #3
i have a kubota b7800, which is very simular to a b2910. same engine, same pump capacity. i run a split fire 3203 three point hitch wood splitter on mine. the splitter has an open valve control to run the splitter and i just use the quick disconnects on the loader and attach the hydrolic lines on the splitter to it. more specific, i use the loader lift up/down ports for the feed/return hoses on the splitter and just use a bungie cord to pull the loader control lever back and that feeds the open valve on the splitter. the splitter won't run until the valve control on the splitter is moved back/forth. when the splitter is not in use, the hydrolic fluid is just flowing through the loader control, back through the open valve on the splitter and back again. i just got my splitter this past summer and have split over a hundred face cord with it. with the b2910 pump capacity it might not split the gnarly wood but my set up has split everything my 25 ton mtd splitter could. the split fire splits in both directions horizontally and i can split about 2.5 face cord an hour. the thing i like about the three point hitch style is i can set the working height of the splitter anywhere i want. a real back saver as i have found most self contained splitters are just a little to low to the ground and bothers my back. i can also lower the splitter to the ground to place the really big blocks of wood on it and then raise it up to work on splitting. also one less engine to maintain. if you want more info on split fire splitters i can get you the info. also i run the tractor rpm between 18-20.
/ Splitter for b2910 #4
I have 40 acres of oak forest, and heat the house with a big Bryan outdoor wood furnace. I have a Brave 26 ton splitter that has been outstanding. After watching a few people hassle around with hooking up and operating a tractor mounted splitter, I would have to recommend this Brave...hands down. I have had it for 9 years, and probably split 8 or 10 cords a year.
/ Splitter for b2910 #5
I also have a split-fire 3 point on my L4400. I have used a stand alone splitter but to me being able to adjust the splitter so I don't have to be bending over is a huge plus. It just takes a couple of minutes to hook up and I'm out in the woods splitting. Also personal preference but I would much rather be listening to my diesel running about 15 hundred rpm to a high pitched gas engine.
/ Splitter for b2910 #6
I have a rankin. Splits in one direction, but can be turned to a vertical position for blocks I can't lift. Be aware that quick connects come in about a million models. If you are going to use the loader quick connects get out your magnifying glass and figure out the maker and model of the quick connect in use. Then buy that type when you have your hydraulic hoses made up. If you are not using a power beyond, but rather running off your loader hydraulics you will need to get longer hoses made (preferably at an industrial hyraulics outfit). Power beyond: $200 to $600. Hoses: $100 to $200.
(BTW when I got a second tractor that I had to match up quick connectors for, I found it easiest to load it up on the trailer, log splitter on the three point and haul the whole thing to the hydraulic shop. They found the adaptors in their bins and made up the hoses in about five minutes.)
Mf
/ Splitter for b2910 #7
I know it is more expense out of pocket up front but believe me, I'd be willing to bet you'll be glad you did it in the long run. What I'm talking about is getting a rear remote installed on your tractor. I had the dealer install it on my B3300 but I've heard that if you already have the FEL, it's not that hard to do. I just didn't feel like messing with it. The additional benefit of the rear remote is that you can then use a hydraulic top link and save your back hooking up attachments and if you have a 3 pt blade, it makes using it more efficient. I had a single spool installed (one outlet, one inlet) and just switch the hoses back and forth when I want to use the splitter.
I got my 16 ton splitter from Woodsplitters Direct. I got it quickly and I'm happy with it. They also have 12, 20 and 30 ton 3 pt splitters but the 16 ton seemed to be the best match for my tractor.
16-Ton Tractor 3 Point Hitch Wood Splitter | Log Splitter
I got my hydraulic top link from haytools.com
Hydraulic top links, Top-N-Tilt, hyd. Side link cylinders
I'm not affiliated with either of the above, just got great service and a very good price.
/ Splitter for b2910 #8
For me the fuel consumption is too high running a log splitter with a tractor. I also don't want to put the extra hours on it.
I split around 20+ full cords a year and use a Super Split, burns about a gallon of gas per three cords split. And does it very FAST! :D
/ Splitter for b2910 #9
For someone that goes through a lot of firewood, a stand alone gas powered splitter may be the best route. I've not compared the speed myself but most people say a stand alone splitter is faster. However, my 16 ton 3 pt has a cycle time of around 18 seconds complete and that's if I use the full stroke of the ram. I put a piece of wood on the splitter, hold the lever till the piece splits then put the lever into the return lock position. In the time it takes me to pick up another piece of wood the ram is retracted. I don't want to have to rush around and work faster than that. I set the tractor throttle to give me 1600 to 1800 RPM so it doesn't burn a lot of diesel. My other consideration is that since I live in SE Texas, my heating needs are pretty short term. With the corn squeezins' we have to burn in our gas powered equipment, I already get tired of cleaning carburetors on the other equipment I have. :mad:
/ Splitter for b2910 #10
I had a LOOP pulled out of the PB from the loader, cost $250 at the dealer,,,,now I can run anything off the back, I love the hydraulic top link the most
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
2025 Future FT-46 Hydraulic Drum Mulcher Skid Steer Attachment (A61572)
2025 Future FT-46...
(3) 6"X34'-1/4" THICK STEEL TUBING (A64280)
(3) 6"X34'-1/4"...
8' DISC HARROW (A60430)
8' DISC HARROW...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
