Spin on grease cartridges
/ Spin on grease cartridges #1
Toddxyz
Huntington WV
Have never operated a tractor. In process of getting my first one.
I recently got one of those spin on tube type grease gun kits from lock n lube. Anybody know where you get just the spin on grease tubes by themselves? I have checked Amazon and the other usual suspects and tried google searching but nothing coming up. Thought these were getting fairly common now a days but I am having no luck finding them.
/ Spin on grease cartridges #2
I’ve never heard of this type of gun. Had to look it up and see what it was. Interesting concept that doesn’t seem to have caught on yet.
Is the only grease I found. Not very convenient and very limited choices it seems.
I wouldn’t mind getting one if it eliminates the constant drippy mess that my guns make. Until I see these tubes at tsc or Napa, I’ll just keep what I have.
  • Good Post
Reactions: JJT
Looks like I had it all wrong. The video below says you can just use any standard grease tube. There is just a round insert "follower" you put in the bottom of the tube. Video explains it better.
The plot thickens. I went to the lock n lube website, clicked on the unit I bought, and in the text it says it ONLY works with the threaded grease tubes. However, the video I posted above said it will work with standard grease tubes. I give up.
/ Spin on grease cartridges #5
Does the plot thicken as the grease thickens? Sorry for the lame joke.
Eric
/ Spin on grease cartridges #6
It’s called a Lube Shuttle. Lock N Lube sells them but they are a bit pricey.
/ Spin on grease cartridges #7
The spin on model is different from the one in the video.
I think the lack of adoption by grease makers is becoming the death of the spin on style.
The Easy Prime grease gun takes standard grease tubes bought anywhere. (see video above).
I don't have one yet, but would buy one if in the market. Lock N Lube company is great. I've been very pleased with my experience with them.
Thanks for the clarification D. I didn't realize it was a different model, thought it was just a different color. I have the version that requires the special tubes. Might send it back to get the version that will take the standard grease tubes.
/ Spin on grease cartridges #10
Use a grease that doesn't separate and it won't make a mess. My guns hang on the walls and set on top of toolbox.
/ Spin on grease cartridges #12
I bought one of these screw-tube type of grease guns about 5 years ago, as I follow this guys YouTube channel -
Perhaps that grease tube 'package of 10' is more affordable than the Lock 'n Lube option
/ Spin on grease cartridges #13
FYI - Ive moved to all Hart tools 20 volt system. It seems a great quality/value system of tools. The electric grease gun is the best I have used.
/ Spin on grease cartridges #14
I have the pistol grip gun that takes standard tubes with the plastic follower, works great. Much easier to change tubes.
/ Spin on grease cartridges #15
I saw once upon a time where Tractor Mike sold them. You may want to give his website a visit. Sorry I don't have the address but I'm sure Google will get you there.
/ Spin on grease cartridges #16
I think I'll just keep using my 30 year old Lincoln grease gun, rather than spend $100 on one with missing parts.
/ Spin on grease cartridges #18
I thought they sold empty cartridges so you could use any grease...?
Regardless, I've been very happy with my lube shuttle gun and grease.
/ Spin on grease cartridges #19
Love my lube shuttle gun. No drips easy mess free changes. I use the ep moly.
/ Spin on grease cartridges #20
I have two about the same age and same brand. Never a priming issue.
2011 KOMATSU D65PX-16 CRAWLER DOZER (A60429)
2011 KOMATSU...
4 BOTTOM PLOW (A60430)
Year: 2003 Make: Dodge Model: Ram Pickup Vehicle Type: Pickup Truck Mileage: 163,513 Plate: Body (A59230)
Year: 2003 Make...
16' 5" METAL STORAGE RACK (A60432)
16' 5" METAL...
2011 Ford Expedition 4x4 SUV (A59231)
2011 Ford...
5000 GALLON WATER TANK W/RELEASE VALVE (A60430)
5000 GALLON WATER...
