Tires Speed accuracy with different tires
/ Speed accuracy with different tires #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
Is the diameter of the Ag tire larger than the Industrial tires? Is the speedometer correct on the grand L series tractors?
(I'm doing that thinking and driving thing again.)
/ Speed accuracy with different tires #2
I don't know the exact answer...but I bet is is close enough! /forums/images/graemlins/grin.gif
/ Speed accuracy with different tires #3
Don,
<font color="blue"> Is the speedometer correct on the grand L series tractors?
</font>
Are you worried about the radars /forums/images/graemlins/blush.gif
/ Speed accuracy with different tires #4
As I remember, the assembly/setup manual mentions an entry to be made electronically to compensate for tire size. Don't know if it discriminates between turf, ag, and industrial tires but that may be reflected in the size designation as well.
John
And the person with the correct answer is ---JMC!! /forums/images/graemlins/smile.gif
I'm not worried about the radar just trying to figure the force of the tractor when I hit a tree! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Speed accuracy with different tires #6
<font color="blue"> I'm not worried about the radar just trying to figure the force of the tractor when I hit a tree! </font>
Gee...no need to figure that one out...answer is obvious...too much! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Speed accuracy with different tires #7
Your Grand L Operator's Manual tells you how to set the speedometer based on the size of the rear tires. It's an easy adjustment.
OrangeGuy
/ Speed accuracy with different tires #8
Just out of curiosity... what is the point of a speedometer on a tractor??? Honestly. I'm curious? /forums/images/graemlins/tongue.gif
/ Speed accuracy with different tires #9
<font color="blue">Just out of curiosity... what is the point of a speedometer on a tractor??? Honestly. I'm curious? </font>
For spraying & fertilizing - when you want to control how much material you let out per acre. You need to know your groundspeed.
/ Speed accuracy with different tires #10
Thanks! I was really worried about people thinking I was being sarcastic but I really wanted to know! I'd never thought to look for a speedometer on a tractor before.
I would think that even if you didn't have a speedometer, but knew your gearing, you could calculate speed based on RPM and gearing... but that probably only works for gear drive tractors...
Just thinking out loud!
Thanks!
/ Speed accuracy with different tires #11
The speed is only part of the equation for spraying and putting on fertilizer. Example fertilizer spreaders tell you where you should be on speed but the type of fertilizer can change that. I have found that with my spreader and tractor the best thing to do is to use low range and go as fast as the tractor can go in the low range. I usually end up with just the right amount of fertilizer that I want to spread. I know I am no where's close to what the spreader says to use as far as speed.
I did use my GPS to determine what speed I was at in each range just for my own information.
murph
/ Speed accuracy with different tires #12
Since radar was mention, a lot of larger Ag Tractors use ground speed radar to tell them actual speed. This is mostly use for planting and applying fertilizer etc.
Dave
New/Unused Landhonor Quick Attach Auger (A61166)
New/Unused...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2020 Bobcat T770 Skid Steer (A61166)
2020 Bobcat T770...
Zero Turn Mower (A59231)
Zero Turn Mower...
40' CONTAINER (A62131)
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
