Speeco Quick Hitch
/ Speeco Quick Hitch #1
mike45tx
South Texas
Mahindra 3510/FEL
Can anyone tell me if a speeco quick hitch will work using a shredder? I can see how it would work fine on a box blade, disc, ect. Also any ideas on mounting a tool box on a 3510?
Mike
/ Speeco Quick Hitch #2
Not sure what you are calling a shredder. /forums/images/graemlins/confused.gif
Is it possibly a rotary cutter? some call a brush hog?
If so, I have a rotary cutter that will attach to my quick hitch (iMatch but similar to the SpeeCo)
RON, Everyone down here in south Texas calls a rotory cutter a shredder.This is my first tractor and all the info I can get is very helpful. If the quick hitch will work the way they say it seems
like the way to go. I read those threads you posted. It looks like I may have some trouble using it. The only good thing is I have not bought it yet. I"ll have the understanding that if it does not work I'll be returning it. Thanks again for your info.
MIKE
/ Speeco Quick Hitch #5
<font color="blue"> calls a rotary cutter a shredder </font>
I believe that a Shredder is a better name than Rotary Cutter. Around here, it is called a Bush Hog no matter who the manufacture is.
/ Speeco Quick Hitch #6
mike,i use a pat's easy change system on my 4500 and will never go back!!
/ Speeco Quick Hitch #7
Mike, Did you look under the floor mat on the left side of your 3510, there is a small tool box located there.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY 14020
/ Speeco Quick Hitch #9
Look under Cabela's ATV attachments and accessories. I saw some for pistol and gun toting there (I was looking for a chainsaw carrier that was mentioned here in TBN, but didn't find it).
Anything on the front of my tractor that is ahead of the grill guard is 'toast' when I am working in the brush. Even then, a stick poked through the grill guard and through the grill screen (but missed the oil cooler and the radiator fortunately). I should get a better grill guard.
Skid Steer Smooth Drum Roller (A65640)
Skid Steer Smooth...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
Crane Carriage System for Steel Baskets (A65579)
Crane Carriage...
