Special mower
/ Special mower #1
oldmech
Quebec
Two Gravely Two L One with 10 h.p Dek-Diesel engine one Grillo 107d and one BCS 735 diesel
Hi! I am working on a side mount sickle bar mower for two-wheels. I work on the drive system (very special) No pitman. All position sickle bar 45deg down and 90 deg up. I reduce 965 rpm speed to 640 by pulleys. Run very well empty. But Yesterday for first time I connect the moving cutting bar. The mower shakes a lot. Too much! I think I must balance the moving parts (Bar with knives) with my drive system. I plan add counter weight. I send pictures soon. Oldmech
/ Special mower #2
Can't wait to see the pictures.:thumbsup:
/ Special mower #3
I used to have a David Bradley sickle mower. From my limited experience, sickle mowers shake under the best of circumstances. A disc mower using grass cutting blades from string trimmers would seem less problematic if you could figure out how to drive them.
/ Special mower
Hi! This is my new mower. I add a wheel at sickle bar end because too much side drag. also I fit a counter wheigt at drive pulley. Now more aceptable shake .
Drive system is a 6 in. pulley with 5/8 5 gr. bolt welded on pulley side. One bearing (6203) turn and slide with drive pulley inside a large slot makes two (3 in. strokes) by turn . This run very well now . But I dont know if the bearing could resist for a long time. I make more test now. Good luck ! Oldmech
/ Special mower #5
That is creative to see a side mount. The Gravely, the David Bradley and other two wheel sickle mowers I've seen were all center mounted and center driven.
/ Special mower
Hi! I make some test yesterday. Run well in all position. Next step . I need a lift system May be a 12 V winch with battery. I want add a second wheel with heavy weight for balance the mower and act as a breake for less drag from the sickle bar on the ground. Thanks! Oldmech
/ Special mower #7
Hey oldmech,
That's pretty wild! I have a piece of literature from mainline that shows a BCS mower offset like that, but with a much smaller bar and only one wheel! I wish I had half your ingenuity.
Bill in WI
/ Special mower #8
How long did it take to make your side sicklebar mower?
I need something like that, for mowing beside my pond, and on the roadside by my farm. (The municipality only seems to mow the roadside once a year now-a-days, and I'd like it mown more often than that.)
/ Special mower
Hi! Grillo make a middle fingers lateral sickle bar mower (No 26598) But 32 in(80 cms) wide from a center drive unit. My sickle bar is 45 in. from center right wheel . I work a lot for make all position drive system 45 deg down and 90 deg up. This run very well. But side drag is so high ( my old sickle bar ( From scrap yard) is too heavy) I cannot drive if not end bar wheel Now i can mow with a side drag . I want correct the drag by a second wheel with heavy weight and a lift system for make the bar more light on the ground. I look for neutral drive.
The more long for make the mower was Plans . I try and test many time. I like make things I have a lot of fun. Later when this mower run fine with no side drag I will send more report and picts. Thanks and good luck! Oldmech
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
