Spec
I am jumping in late on this thread, but I believe I am following everything correctly and believe CoyPatton is on the right track here. You would have 2 way hydraulics if you used an external control valve, but would only be used for an implement not associated with your 3ph pump, it would have to be ran off your engines hydraulic pump.
Any luck on a loader?
Uh, y'all do know this is a 7 year-old thread, right?:confused3:
/ Spec
No, spent quite a few months looking for one and found nothing, ended up buying a bigger tractor that had loader on it but have since found a place a couple hours from us that sells them that would fit this tractor
Well I guess if you end up with another yanmar you know where to go. What tractor did you end up with? Hopefully it is filling your needs
/ Spec
Still got the Yanmar but got a Massey 135 with loader and in process of buying a skid steer
Glad to hear you kept the Yanmar! And does your Massey 135 have the 35hp Perkins diesel? That tractor is much bigger than your YM169.
2017 Genie GTH-5519 (A53317)
2017 Genie...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Takeuchi TB016 (A53317)
Takeuchi TB016...
John Deere TX Gator (A60462)
John Deere TX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
