Spacer / reducer from 1" to 3/4" question
   / Spacer / reducer from 1" to 3/4" question #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I purchased a new hydraulic cylinder. The ends are 1" ID. My machine takes .75" ID. Is there something easy and over the counter that I can slip in to take up this gap, or do I have to go get something machined.
Thanks
Carl
   / Spacer / reducer from 1" to 3/4" question #3
Hello
You probably don't want to use a 1 to 3/4 NPT bushing in a hyd system.
The external and internal threads create a thin cross section and they will crack in the threads.
You need at least 2 size difference to use a bushing safely. Even better is find the adapter you need from 1" to your hose.
   / Spacer / reducer from 1" to 3/4" question #4
Hello
He is talking about the pin end-or clevis ends, not the hydraulic ports.
   / Spacer / reducer from 1" to 3/4" question #5
Your local tractor/ag store should have the appropriate bushings. I have always been able to get them there.
I hope you get your chance at seat time during tulip time.
Ken
   / Spacer / reducer from 1" to 3/4" question #6
Isn't that the same size bushing that reduces Cat 1 to Cat 0 pins?
This is also a common reducing bushing for trailer hitch ball shafts. TSC, Ace Hardware, etc.
   / Spacer / reducer from 1" to 3/4" question #7
A bronze bushing would work not rust ect check mcmaster carr
tom
Thanks guys!
Yeah, seat time. Got into a fight with the wife. Was shortsighted an pulled a temper tantrum and told her we were not going home afterall. Grumble...... Now either I have to kiss and make up, and even though she is way wrong tell her I am wrong and we can go, or suffer and not get any seat time.
For my own edification, brass would be too soft in a hydraulic end link spacer setting, wouldn't it?
   / Spacer / reducer from 1" to 3/4" question #10
McMaster-Carr
Part Number: 8491A755
8491A755
Steel Press-Fit Drill Bushing/Liner 0.75" (3/4") ID, 1" OD, 1-3/4" Length
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2014 Volkswagen Passat TDI SE Sedan (A50324)
2014 Volkswagen...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
