Spacer / reducer from 1" to 3/4" question
   / Spacer / reducer from 1" to 3/4" question #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I purchased a new hydraulic cylinder. The ends are 1" ID. My machine takes .75" ID. Is there something easy and over the counter that I can slip in to take up this gap, or do I have to go get something machined.
Thanks
Carl
   / Spacer / reducer from 1" to 3/4" question #3
Hello
You probably don't want to use a 1 to 3/4 NPT bushing in a hyd system.
The external and internal threads create a thin cross section and they will crack in the threads.
You need at least 2 size difference to use a bushing safely. Even better is find the adapter you need from 1" to your hose.
   / Spacer / reducer from 1" to 3/4" question #4
Hello
He is talking about the pin end-or clevis ends, not the hydraulic ports.
   / Spacer / reducer from 1" to 3/4" question #5
Your local tractor/ag store should have the appropriate bushings. I have always been able to get them there.
I hope you get your chance at seat time during tulip time.
Ken
   / Spacer / reducer from 1" to 3/4" question #6
Isn't that the same size bushing that reduces Cat 1 to Cat 0 pins?
This is also a common reducing bushing for trailer hitch ball shafts. TSC, Ace Hardware, etc.
   / Spacer / reducer from 1" to 3/4" question #7
A bronze bushing would work not rust ect check mcmaster carr
tom
Thanks guys!
Yeah, seat time. Got into a fight with the wife. Was shortsighted an pulled a temper tantrum and told her we were not going home afterall. Grumble...... Now either I have to kiss and make up, and even though she is way wrong tell her I am wrong and we can go, or suffer and not get any seat time.
For my own edification, brass would be too soft in a hydraulic end link spacer setting, wouldn't it?
   / Spacer / reducer from 1" to 3/4" question #10
McMaster-Carr
Part Number: 8491A755
8491A755
Steel Press-Fit Drill Bushing/Liner 0.75" (3/4") ID, 1" OD, 1-3/4" Length
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
2016 Ford Escape SE AWD SUV (A50324)
2016 Ford Escape...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
