Source for diesel inline fuel filter
/ Source for diesel inline fuel filter #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
Anybody know of a good inline fuel filter. I'm re-powering a garden tractor with a Lombardini diesel. There isn't room for a large filter and was hoping to use an inline suitable for diesel. The original Lombardini specs call for a 5 micron filter.
Thanx
M.D.
/ Source for diesel inline fuel filter #2
What size hose are you running? I can look one up for you in a Fleetguard or Donaldson catalog but need to know what size hose you are running.
/ Source for diesel inline fuel filter #4
A Fleetguard FF5480 is a fuel filter for a ONAN engine and has a .26 inch inlet and outlet.
If you want a metal housed filter try a Fleetguard FF5066 (Fram G1), it is a true 1/4 inch inlet/outlet filter. This is probably the best for your application as it is intended for diesel engines and is a factory filter on BOBCAT'S with WISCONSIN, KOHLER, ONAN and DEUTZ AG diesel engines.
Thanx alot for the info!
I'll pick one up tomorrow and take it for a test drive.:D
Tried a G1, it won't flow enough, must need a fuel pump. I need something for gravity feed. I'll keep searching.
M.D.
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A66734)
2025 GIYI GY-P45...
2006 KENWORTH T300 (A67714)
2006 KENWORTH T300...
