Source for diesel inline fuel filter
/ Source for diesel inline fuel filter #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
Anybody know of a good inline fuel filter. I'm re-powering a garden tractor with a Lombardini diesel. There isn't room for a large filter and was hoping to use an inline suitable for diesel. The original Lombardini specs call for a 5 micron filter.
Thanx
M.D.
/ Source for diesel inline fuel filter #2
What size hose are you running? I can look one up for you in a Fleetguard or Donaldson catalog but need to know what size hose you are running.
/ Source for diesel inline fuel filter #4
A Fleetguard FF5480 is a fuel filter for a ONAN engine and has a .26 inch inlet and outlet.
If you want a metal housed filter try a Fleetguard FF5066 (Fram G1), it is a true 1/4 inch inlet/outlet filter. This is probably the best for your application as it is intended for diesel engines and is a factory filter on BOBCAT'S with WISCONSIN, KOHLER, ONAN and DEUTZ AG diesel engines.
Thanx alot for the info!
I'll pick one up tomorrow and take it for a test drive.:D
Tried a G1, it won't flow enough, must need a fuel pump. I need something for gravity feed. I'll keep searching.
M.D.
2025 Swict 60in Bucket Skid Steer Attachment (A66734)
2025 Swict 60in...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
ALLMAND ECO-LED LIGHT PLANT (A68842)
ALLMAND ECO-LED...
2000 PETERBILT 378(INOPERABLE) (A67714)
2000 PETERBILT...
CAT 621B Transmission (A68134)
CAT 621B...
CAT D6 Limb Sweeps (A68134)
CAT D6 Limb Sweeps...
