Source for diesel inline fuel filter
/ Source for diesel inline fuel filter #1
Mighty Dodge
Platinum Member
The Hereford Zone, MD
JD 4200
Anybody know of a good inline fuel filter. I'm re-powering a garden tractor with a Lombardini diesel. There isn't room for a large filter and was hoping to use an inline suitable for diesel. The original Lombardini specs call for a 5 micron filter.
Thanx
M.D.
/ Source for diesel inline fuel filter #2
What size hose are you running? I can look one up for you in a Fleetguard or Donaldson catalog but need to know what size hose you are running.
/ Source for diesel inline fuel filter #4
A Fleetguard FF5480 is a fuel filter for a ONAN engine and has a .26 inch inlet and outlet.
If you want a metal housed filter try a Fleetguard FF5066 (Fram G1), it is a true 1/4 inch inlet/outlet filter. This is probably the best for your application as it is intended for diesel engines and is a factory filter on BOBCAT'S with WISCONSIN, KOHLER, ONAN and DEUTZ AG diesel engines.
Thanx alot for the info!
I'll pick one up tomorrow and take it for a test drive.:D
Tried a G1, it won't flow enough, must need a fuel pump. I need something for gravity feed. I'll keep searching.
M.D.
2022 CATERPILLAR 259D3 SKID STEER (A65056)
2022 CATERPILLAR...
CAT IT28B Cab (A68134)
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
CAT D6 Limb Sweeps (A68134)
CAT D6 Limb Sweeps...
Unused 2026 CID SNLB84-S 84in. Snow/Ice Skid Steer Bucket Attachment (A66734)
Unused 2026 CID...
CAT D9G Springs (2) (A68134)
CAT D9G Springs...
