sometimes i get interesting jobs.
   / sometimes i get interesting jobs. #1
pmsmechanic
Elite Member
Southern Alberta, Canada
4410 and F-935 John Deere, MF 245
My neighbor brought me his bale truck and asked me to fix it. Both frames are cracked. One is cracked all the way through and the other side had about an inch of frame that isn't cracked. I offered to change the frame but he didn't want to spend the money and I don't blame him. For what the truck is being used for a repair will do an adequate job.
The first picture in the attachments is supposed to go here.
Here I'm starting to get the frame lined up.
This is what i did to pull everything into place.
Finished product and i added a cross member as i figured the reason why the frame had cracked was because it was flexing in every time a bale was picked up.
I also added blocks between the frame and the bake deck to help support the load.
We will see in a few years how this holds. The truck isn't registered and only gets used in the fields and corrals.
   / sometimes i get interesting jobs. #3
If those plates were all that transferred the load to the frame, that would explain why it cracked.
   / sometimes i get interesting jobs. #4
If you still have the truck. How about adding fish plates.
I never thought of that and I like the idea. There is room if the cross brace was shortened which would be possible. Right now the plan is to keep an eye on it watch for new cracks. The deck would need to be removed again and though that's not fun it's not the worst job either. The truck is only a couple of miles from my place and I'll be seeing it once in a while.
Just curious as to why there are tabs welded in top left and bottom right on the picture of the fish plate?
   / sometimes i get interesting jobs. #6
I don't know, I stole that picture off a welding forum as a really good example of a fish plate.
That is a normal Dewese method of mounting bale decks and there are a lot of decks out there mounted like that. This is not the first one I've seen cracked but there are a lot that never crack.
The decks are mounted by solidly bolting the rear of the deck to the frame and then two of these plates on each side to transfer the load to the frame.
The truck is a first generation 250 Cummins that has been converted to a dually with adapters on the rear axle. I haven't done any measuring but I wouldn't be surprised to find that a Dodge 350 has a deeper frame. I drive a 90 250 Cummins for my work and have a 91 for parts. The frame on the 91 is an inch deeper.
   / sometimes i get interesting jobs. #8
In my opinion the tabs at the ends of the fish plate were added in order to tie in the flanges of the channel to add extra flex resistance.
   / sometimes i get interesting jobs. #9
I was wondering why no fish plates as well. The rounded corner diamond shape is important to prevent future cracking. Something I was taught way back when. A question for Shield Arc. What thickness fish plate in relation to the base metal would be appropriate for the chassis repair? Both sides or one side?
   / sometimes i get interesting jobs. #10
Only time I ever did fish plates was on dirt moving equipment. That was 1/2" and 3/4" thick material. I've read where guys say for truck frames don't go over 1/4" thick. If at all possible, I would fish plate both sides.
2018 UTILITY VS2DC 53FT REEFER TRAILER (A52141)
2018 UTILITY VS2DC...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
1998 East Frameless Dump Trailer (A50774)
1998 East...
2014 Mack CXU613 Semi (A50514)
2014 Mack CXU613...
