Something I found behind the barn
/ Something I found behind the barn #1
1948berg
Southern Norway
A Fergie-MF 35 gas- Mf 165- Mf 6161- Unimog- Fiat 880
This thing was ment for something else, now I used it to pull a few logs out of the forest. Works very fine!
/ Something I found behind the barn #2
Looks nice and simple. Reminds me that if I don't get firewood out of the woods soon I am going to regret it!
What is mounted on the left rear corner of your cab? Is it a radio antenna?
thanks for sharing the picture.
Hurry, it was muddy already!
It is a "bayonet" coupling for the rotating yellow warning light.
/ Something I found behind the barn #4
Lately those attachment have been poping up at small tractor shows also forestry shows...even offer grappler.
One had to keep tight hitch near the base of the tree when hauling,for if not the tire chains would start the debarking...yikes..also we add a travel chain,chain to lower bar center than hook to home made clevis bolted under the seat,than lower 3 pt.hitch until free from log weight....less strain on 3pt. hitch...work pretty darn good.
/ Something I found behind the barn #5
Gunnar,
Is that a license plate on the left post of your ROPS? Can you legally drive your tractor on roads?
Anyway, if your implement works, use it! Looks like it works great...Kyle
/ Something I found behind the barn #6
I've only ever had to skid a few trees, and just used the arch from my post hole auger without the auger attached. Lifts the butt up pretty good and not too close to the back wheels. Probably not strong enough for big honkin trees , but for the smaller stuff it seems to work O.K.
Kyle_in_Tex said:
Gunnar,
Yes, I can legally drive on roads. It is the license plate. I can even drive on roads with an unregistred tractor, but then just to another part of my property. Between fields.
/ Something I found behind the barn #8
So what was it originally?
This is what I use for skidding logs with. I need to add a small mast to it though, something similar to yours.
/ Something I found behind the barn #9
BTW.... 1948berg...
That is one nice set of chains that you've got there. A set like that is in my near future.
And a QA,
And a Small grapple,
And....
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
iDrive TDS-2010H...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A64276)
2020 FORD F-150 XL...
TAKEUCHI TL230 SERIES 2 SKID STEER (A64279)
TAKEUCHI TL230...
Caterpillar 950B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 950B...
