Some one been there and done This
   / Some one been there and done This #1
Dan Lamb
MC Cloud Ca
Branson 2400h TLB/ cab
Hey guys ,
I will be getting a grapple and a Third function valve but not for a couple months , for now was going to Get 11/4鋳 steel tubing and bolt 3 pieces on my bucket and weld a couple of out riggers for more support to pick up brush piles .I have small piles everywhere on my 2.5 acres. Have any of you guys done this or any good ideas would be great $50.00 bucks for the steel have to Save up for the grapple and valve , Everything Attachments Grapple and True Third Function Valve . Thanks any advise is appreciated , Nor Cal Dan
   / Some one been there and done This #2
For the steel, bolt up the steel like this_________/, and bolt it on your bucket. Tip your bucket down and use them like a spoon, scoop and tilt up. As far as the grapple, I refused the third function valve, and simply disconnected the bucket roll, and used that for the top jaw. Look up "add a grapple" Bolts on your bucket!
   / Some one been there and done This #3
Do image search for debris forks, you should come up with a bunch of ideas that might help you out.
Thanks guys for the info , I would post some pictures but the instructions on how to post pictures seems long winded , way more complicated than IT should be .If IT is simple please let me know, Dan
   / Some one been there and done This #5
Thanks Farmboy, I will give IT a try
   / Some one been there and done This #7
For my grapple control, I plumbed into the rear remote circuit I have and put a set of connectors where the loader comes off of the tractor, and ran them from there up the loader with the other lines. So my "Grapple Grip" is run off of a separate stick in the cab just a few inches from the loader control and those lines can be quickly disconnected when I take the loader off.
2005 GMC C7500 24FT BOX TRUCK (A59904)
2005 GMC C7500...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
LIGHT TOWER (A56857)
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
