soldering copper gutters
/ soldering copper gutters
Some sage words from another "I'll do it mysefer". I know what you mean about getting into small projects that turn into big projects. I little follow up to my situation...I met will a getter installer who does copper, and the way he explained it, it's all about control. As you guessed from your own experience, the irons allow you to put a bead of solder between the the pieces without overheating, discoloring and without loosing solder all over the place. Well, I haven't made up my mind yet, but his quote is looking mighty tempting. Best part is, if I let the pro do it, it frees me up for other projects, like ones that involve the new tractor. Thanks for your response.
/ soldering copper gutters #12
The best and most reliable way to seal copper gutter seams is to use solder. A properly soldered seam will have the same life as the gutter. If you use caulking or sealant it will only seval months to a year or so.
As for whether to use a flame or iron, the iron is far better. Irons provide a stable concentrated heat source and provide a much easer way of pin pointing the heat to draw in the solder.
/ soldering copper gutters #14
This has got to be a record. :eek:
Welcome to TBN Ralph:D
What Willl means is you dredged up a 7 year old post:eek: Hopefully the OP got those gutter's fixed by now;)
/ soldering copper gutters #15
It might be a record but Ralph the roofer is right on how to do the job. I use to have some of those really big iron/coppers for doing a raised seam metal roof. It takes a good man to hold one of them all day.
/ soldering copper gutters #16
Yowza.. 7yrs:D
But yes a iron is the proper tool
/ soldering copper gutters #17
Yup- back about 1973 I worked at a college maintenance facility in sheet metal, which also included gutter repair and fabrication. Part of that was duplicating and repairing ancient guttering on civil war era buildings.
We too used a big ole copper soldering iron heated in a propane burner, the iron itself was probably 2 lbs or more on the end of a steel rod with a handle.
You could lay down a great seam that looked beautiful and well defined, I defy anyone to do it with a torch and make it look that pretty.
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2020 DRAGON ESP...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
