soldering copper gutters
/ soldering copper gutters #1
bellweather
Platinum Member
Western MA
Kubota BX22
I'm planning to install copper gutters and from what I've recently learned, the best way of soldering the joints/seams is with a soldering iron (not the electric kind used for joining wires to PC boards). I was under the impression this could be done with a propane torch, much like sweating copper plumbing joints. Anyone out there with experience who can offer some advice or pointers? Thanks.
/ soldering copper gutters #2
I remember as a kid seeing copper gutters on an old hospital building. I asked my father about them, and he explained how they were installed. They would overlap the gutters in the direction of the pitch 2 to 3 inches. Some people used tar, and other people used lead joints like solder to join them.
This is from memory and may not be accurate, but I hope it helps....
Joe
/ soldering copper gutters #3
I remember that one of those home improvement programs. This Old House I think, did a program about copper gutter about a year ago. Maybe they have something on their website about it.
/ soldering copper gutters #4
Not having ever soldered copper gutter specifically ( but have soldered copper, brass, bronze, tin, etc parts and sheets, etc ) I would think it would be a fairly easy job. Clean the joints, use a grease flux or pretreater ( some are acid base.. may make some attractive green oxidation.. but then that's what makes copper look good and antique ). Heat the joint with a propane torch, or equivalent, get the solder flowing, and it should sweat like a pipe if the fit is good, or at least fairly close.
Soundguy
/ soldering copper gutters #5
Bellweather,
This is just my guess, but I bet the use of the old style soldering iron is to keep from discoloring the copper at the joints. I think the torch will cause some discoloration but sure don’t see any reason a torch would not work.
MarkV
/ soldering copper gutters #6
I asked a friend who has a seamless gutter business your question. I've seen copper material on his rig so I knew he did it.
He says he does it the same way he does aluminum. He uses rivets and gutterman's friend which is some of the nastiest goodest stuff for sealing up cracks etc.
The difference is when he does copper he uses brass rivets.
He said he's only seen big commercial jobs done with soldered copper. And those guys carried what sounded like to me as rivet forges. He said they had buckets with hot coals that kept the irons hot.
You might look into a Henrob torch. They're an oxy acetyline torch that's unlike anything you've ever seen. I got mine because I was trying to get fancy with some aluminum.
What's trick about them is you set the regulators at four psi oxygen and four psi acetyline. Yup, four psi, blow your mind if you have one.
I've been hammertoning some plate. I've got four hammers and I've been wearing out the steel and my arm putting all these dents of different shapes into the steel. In the back of my mind I've wondered what it would like to have the dents filled with brass and then the whole thing sanded down smooth.
So last night I grabbed a short piece of scrap and beat some dents in it with a cross pein that I'd broken off an edge. The dent it makes looks like a half moon, kinda cute, making lemonade out of lemons you might say.
I then pulled out the Henrob and set it up. I'd read in the manual that you didn't need flux to braze. So being a believing sort I picked a tip and then some brass rod and heated up a dent after cleaning it. Stuff worked finer'n a frog hair split three ways. No flux just like the manual said. Supposedly the flame pattern is such that it keeps the welding area pure, sorta like a tig principle I guess.
They're expensive, about three and a half, but if it does copper anything like it does brazing you'll be happier than a pup with two tails within the first hour of using it.
BTW if you happen to see Motorcycle Mania on Discovery channel where that weirdo Jesse James is using a torch to put together a custom aluminm tank, that's a Henrob working.
/ soldering copper gutters #7
Here's a link to a thread on the Henrob <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=rural&Number=105046&fpart=1>click here for the Henrob thread</A>
/ soldering copper gutters #8
bellweather:
<A target="_blank" HREF=http://www.classicgutters.com/aboutcgs.html>Classic Gutter Systems</A> was a company who has been featured in This Old House. I was actually ahead of the curve (for once), and used their aluminum half-round gutters for my 1830 house in Bolton MA (I miss that one) about 8 years ago. When we moved to WI, the new "cape" that we have now had no gutters around the three-side porch. I decided to go back to Classic and order up their copper half-rounds. The gutters were cut (on a miter for the corners), and then a flashing was fitted around the outside of the two pieces and fastened with screws (this all came with the order). What was left was the flux and soldering, and I used a propane torch for that. It worked just fine, it's just like doing copper pipes (with the exception that I came unglued from the ladder).
I imagine that you could use a polyurethane caulk/sealant, which is what they recommend for the aluminum joints (that stuff is really sticky---takes a few days to fully cure). For copper tho, I'd probably stick with a torch. It's not hard, and you really don't need any additional equipment.
Thanks for the response. It appears that soldering with a propane torch should be no problem. I'm familiar with sweating copper plumbing, and if it's similar to that, I should have no problem. Still, I'm wondering why sheet metal roofers use soldering irons and not torches...perhaps to avoid discoloring or distorting the thinner gauge materials? or maybe to avoid setting the house on fire? Anyway, I'm going to try a few test sections with my torch ans see what happens. Thanks again for the help.
/ soldering copper gutters #10
<font color=blue>Still, I'm wondering why sheet metal roofers use soldering irons and not torches...perhaps to avoid discoloring or distorting the thinner gauge materials?</font color=blue>
I suspect there's a couple of things going for the irons. I'm sure a lot of it has to do with the control of the heat and solder. With an iron I would bet you can get much more pin point control of the heat and you don't have to worry about over heating.
You're probably right about the fire hazard also. You might consider picking up an old iron and then fab'ing out of say five sixteenths steel rod a holder so that you can use map gas or propane to heat the iron. Some practice on some scraps will surely make you a capable DIY in no time at all. The use of coals and multiple torches has to be all about efficiency and speed.
A note of safety might be appropriate. I'm notorious at tackling projects that should never have been done and doing them for entirely too little money. One of these projects was making some brass stands for a pair of antique carousel horses.
Nothing but a thing I told the customer and figured I could do it in a day, maybe two. It took a week. I decided to use sixteen gauge inch and a half brass round tubing. Bending them was nothing as I knew a muffler shop who had some of the unusual dies for their benders that most shops don't carry anymore.
But welding brass with oxy acetylene is an absolute bugger bear and I'm sure the same is true of copper. The biggest reason that brass and copper are such bugger bears to gas weld is the heat transfers instantly. You can't make a little red dot and dab in some filler like you can with aluminum or steel.
So I found myself doing about ninety percent of a butt weld in this tubing to find that last ten percent never ending. I'd be moving the puddle forward as the previous weld kept the same pace but falling in as it'd melt.
I guarantee you that there were more bad words on that concrete than there have ever been in total on any junior high playground.
So with your copper you might find the same problem. As you move the solder with the torch the area of heat enlarges and what you've just done runs away to play with the bugs in the grass. Or you might do like I did and accidently touch a place four feet away and find it just as hot as where you had just worked the torch.
The stands turned out great. But they're pretty high up on that list I have of "been there, done that, wore out the shirt, and threw away the hat. Never again." (I'd tig them)
Some sage words from another "I'll do it mysefer". I know what you mean about getting into small projects that turn into big projects. I little follow up to my situation...I met will a getter installer who does copper, and the way he explained it, it's all about control. As you guessed from your own experience, the irons allow you to put a bead of solder between the the pieces without overheating, discoloring and without loosing solder all over the place. Well, I haven't made up my mind yet, but his quote is looking mighty tempting. Best part is, if I let the pro do it, it frees me up for other projects, like ones that involve the new tractor. Thanks for your response.
/ soldering copper gutters #12
The best and most reliable way to seal copper gutter seams is to use solder. A properly soldered seam will have the same life as the gutter. If you use caulking or sealant it will only seval months to a year or so.
As for whether to use a flame or iron, the iron is far better. Irons provide a stable concentrated heat source and provide a much easer way of pin pointing the heat to draw in the solder.
/ soldering copper gutters #14
This has got to be a record. :eek:
Welcome to TBN Ralph:D
What Willl means is you dredged up a 7 year old post:eek: Hopefully the OP got those gutter's fixed by now;)
/ soldering copper gutters #15
It might be a record but Ralph the roofer is right on how to do the job. I use to have some of those really big iron/coppers for doing a raised seam metal roof. It takes a good man to hold one of them all day.
/ soldering copper gutters #16
Yowza.. 7yrs:D
But yes a iron is the proper tool
/ soldering copper gutters #17
Yup- back about 1973 I worked at a college maintenance facility in sheet metal, which also included gutter repair and fabrication. Part of that was duplicating and repairing ancient guttering on civil war era buildings.
We too used a big ole copper soldering iron heated in a propane burner, the iron itself was probably 2 lbs or more on the end of a steel rod with a handle.
You could lay down a great seam that looked beautiful and well defined, I defy anyone to do it with a torch and make it look that pretty.
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2017 Ford F-150 Pickup Truck, VIN # 1FTEW1C85HFB72710 (A61165)
2017 Ford F-150...
2006 Ford F-650 24ft. Flatbed Truck (A61568)
2006 Ford F-650...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
72in Bucket Skid Steer Attachment (A61567)
72in Bucket Skid...
