Solar Battery Tender
/ Solar Battery Tender #1
DeeDubya
San Marcos, TX
Branson 2910i
Any recommendations for a good solar battery tender? I'm thinking one of the solar gate opener charger units should work because they use a car battery but I'm sure someone has one for keeping tractor batteries charged. I don't have power nearby and am having to run the tractor at least every 2 weeks to keep it charged.
/ Solar Battery Tender #2
Just got emailed an ad for a 10 watt Coleman branded one they are selling at half price at Northern Supply (about $40). Had good reviews for just the type of application you are considering.
mf
/ Solar Battery Tender #3
BatteryTender has one. I saw it demoed on TV on Gearz. I have two BatteryTenders (not solar) and if it works like those it's first rate.
/ Solar Battery Tender #4
I have used one of these for years on my garden tractor, Works well. I cannot remember for sure If I got it at HF, but most likely did. In any case, it looks just like it. As for an AC charger, I agree the Battery Tender brand is first rate.
1.5 Watt Solar Battery Charger
James K0UA
mf
It that's Norther Tool and Equipment you're talking about I can't find a 10w Coleman on their website unless maybe it's a discontinued unit.
James K0UA
I'm wondering if that's big enough for a full size tractor battery? I'm thinking at least 5 watts?
/ Solar Battery Tender #7
If your battery goes dead in two weeks something is wrong.:(
The battery is NG or there is a draw from a circuit in the tractor. You should be able to leave it for months without a problem. Some of my tractors sat for extended periods with no problems and a few were six volt.
I've just replaced the battery so I'm not sure now how long it would last without charging. I don't like taking a chance with it running down because getting my truck close enough for a jump start is difficult. Thanks for the advice but I'm still looking for a solar battery maintainer.
/ Solar Battery Tender #10
Here is my experience, My Kubota sometimes sat for over a month in the winter without starting, without a maintainer of any kind and no problems, I understand the desire for the maintainer, and think it a good idea. I have run the maintainer for my garden tractor for several years, just because it will sit for months without starting. My thoughts about the maintainer are this: If the new battery is in good condition, all you are making up for is the internal losses in the battery. In other words if there is no electronics/electrical externaly drawing down the battery, then the only losses is the internal resistance leakage currents inside the battery that eventually discharges them. These internal losses are very small, but do add up over a period of time. I would think a small 1.5 watt maintainer would be plenty to keep up any size tractor battery from internal losses even during the cold/dark days of winter. On the other hand, keep in mind that a larger solar panel can pump out more current, and these panels are unregulated unless you install a charge controller and you run some risk of "cooking" your battery with the voltage and current the solar panel can generate over time. The battery will drop the open circuit voltage of the solar panel (which can exceed 24V) to a safe level until the battery reaches full charge, then the voltage will continue to float up and up, and the battery will outgas hydrogen and oxygen. So I would not be sticking a larger panel than a 1.5 on a battery without a charge controller. Even one of those in summertime with a lot of bright days and high sun angles might not be a good idea to leave on all the time. Also it has registered in my brain now that I have a tractor with actual Electronics on-board not just electrical things, that connecting even the 1.5 watt controller (still a very high open circuit voltage) without any type of voltage regulation on it may not be a good idea. Yes the battery will drop that high voltage very quickly (milliseconds?) but still it is a transient high voltage spike I am introducing into the electrical system for a small amount of time. Microprocessors do not like high voltage spikes. and have been know to lock up, roll over and die etc. Use the maintainer with caution, and one with a charge controller might be a good idea.. Not to pee on your project, but to caution you.
James K0UA
/ Solar Battery Tender #11
I have the 1.5 HF, it is a charger not a floater. I used to leave mine on continuous in the winter and I was concerned it was actually overcharging, now i do it intermittently. It didn't seem to have any issue keeping a full sized battery charged.
/ Solar Battery Tender #12
I put a 12 volt solar panel on a battery on a gate opener that puts out 15 watts under full sun. I has no regulator per say only the one on the panel itself to keep it at 12 volts constant, but the wattage varies due to amount of sun on it. It just sets there pumping in 15 watts at 12 volts so that is 1.25 amps and it has been on that battery for over 2 years and everything is still working perfectly. The gate usually doesnt open and close more than 2 times per day and sometimes not for day at a time but it hasnt over charged or undercharged at least not enough to damage the battery. It keeps 14 volts showing when I check it.
I have everything else that I dont use frequently on the 1.5 amp electric chargers except my big tractors and they just set and wait on me for a few months at a time. They always crank. But there is absolutely no drain on them either. My diesel lawnmower would do the same, but the battery is over 4 years old now so I decided to keep it pumped up so I can get a few more years from it. It is lots bigger than the typical lawnmower battery.
/ Solar Battery Tender #13
I drive a truck for a living so my diesel pickup will sit at the terminal sometime for months at a time . It used to be common for me to get into town, and the dome lights wouldn't even come on. I bought one of the NT 1.5 watt solar chargers and problem solved ! I did forget it ! time and was cussing myself when I got home and had to jump the pickup off at 3am ! I think 1.5 watts is fine for the parasitic loads . seems to do go for me !
2008 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2008 CATERPILLAR...
1604 (A57192)
1604 (A57192)
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2002 Freightliner...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A59230)
2007 Western Star...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
