So this happened. BXPanded Underarmor destroyed.
/ So this happened. BXPanded Underarmor destroyed. #21
Doesn’t it have diamond plate facing down? When I first saw that I thought the diamond plate surface would tend to catch and hang up on rocks or other obstructions but then not everyone has to deal with big rocks like I do.
I ended up making my own skid plate from 1/4” steel plate and so far it’s worked fine.
/ So this happened. BXPanded Underarmor destroyed. #22
I'm still trying to figure out where this goes?
/ So this happened. BXPanded Underarmor destroyed. #25
That needs to be at least 1/4" thick material to not get mangled.
/ So this happened. BXPanded Underarmor destroyed. #26
Kinda what I was thinking too. Looks a little spinnley.. IDK..especially if it bends like a soup can.
/ So this happened. BXPanded Underarmor destroyed. #27
I found this short video showing how it is removed. BXpanded Under Armor: How easy is it to remove?? - YouTube
Okay, after watching this video, it is very evident as to what happened to the OP's skid plate. In my mind, this is a terrible design. When the 3 point hitch is in the low position, the skid plate hangs down at an angle. It would be okay when going forward, but if you try to back up with it hanging down, it's going to dig into a stump or rock and get trashed. OP said he was brush hogging when this happened. I assume he had the 3 point hitch down, to lower his flail mower.
It seems like a really poor design.
Also, from the video, that plate does not look 1/8" to me. Looks more like 12 or 13 gauge.
/ So this happened. BXPanded Underarmor destroyed. #28
Just watched the video below, and the narrator states, "you must keep the deck knob in the top position". I'm not familiar with the BX series, but it looks like you can set the knob to keep the MMM in the raised position. Go to 05:40 in the video below.
Geonnibravo, is it possible your deck knob broke, or wasn't in the TOP position?
/ So this happened. BXPanded Underarmor destroyed. #29
It would indeed be a terrible design it was ever hanging down when in use! But that would be extreme operator error. The Kubota BX MMM lift arms can easily be locked in the "up" position, just by twisting the height control knob to the "top" position. Once there, you can raise lower the 3ph arms to your heart's content and the under armor will not budge, and won't even rattle.
I've bought quite a few accessories for my tractor, and this was absolutely the best, and a really good value. It's very easy to install/remove, more than strong enough to perform it's job, and very effective in protecting fragile things below the frame.
Whatever went wrong with the OP's wasn't because of a poorly designed product, in my mind. Not sure why so many want to bash it without having seen it in person, and correctly mounted on a BX tractor.
/ So this happened. BXPanded Underarmor destroyed. #30
After watching this video, we all know, including the OP what happened and what he failed to do and why it got wadded up. End of story.
/ So this happened. BXPanded Underarmor destroyed. #31
Armchair quarterbacks. Web forums are full of them, all are experts on things they've never owned or used.
/ So this happened. BXPanded Underarmor destroyed. #32
Yes, there should be disclaimers. I have never owned one or used one, but . . .
Yet generic information can be usefull. You make such a guard too strong, and you could do major damage to whatever it is attached to, if you strike something. It would be like using a heavy I beam for a truck bumper. Now you hit something and you will bend your frame!
/ So this happened. BXPanded Underarmor destroyed. #33
All true. It seems the OP neglected to lock the mmm linkage up and proceeded to wreck the plate while moving in reverse.
Operator failure.
/ So this happened. BXPanded Underarmor destroyed. #34
Ouch. I managed to do something like that with a BroTek belly plate. Not that bad, but had to drive over it with the pickup to straighten it.
In my case it was a problem with "the loose nut behind the wheel". Reminder to me to leave the equipment alone when sleep deprived.
Z.
You bent your BroTek belly plate? Wow, that would take some doing. I have it on my BX 25 and it is really tough. And it bolts on very securely.
/ So this happened. BXPanded Underarmor destroyed. #35
Yep. You know the saying: "one oh-bleep cancels all your atta-boys" ? It was one of those deals. Exceptionally stupid on my part. Hate to 'fess up, but they say confession is good for the soul. Was a good sharp whack with the clue bat, and hopefully a permanent reminder to _never_ treat the equipment casually, never get in a hurry, and PAY ATTENTION!
I'd been 'hogging most of the day. Very tired, very crispy. About an hour away from done the go-pedal started behaving strangely. Very limited fwd speed, but the engine seemed to be running fine. Put it on the trailer for easier access, and dropped the back of the belly plate to examine the linkage, since it seemed like the pedal range of motion had become restricted.
Couldn't find anything obvious, and spent a lot of time on it. Finally realized that somehow I had gotten a tiny pebble on top of the pedal pivot assembly, and it was keeping it from fully depressing.
Yay! Back it off the ramp trailer and finish the job... It's a ramp trailer so when backing off the tractor tips up @ the front. OK, ... but I'm not on the ramps yet! In my haste I had left the belly plate down at the back and it had jammed into the trailer deck and lifted the front of the tractor. And bent.
Finally the last functioning brain cell took over. Pulled forward. Pulled the key. Walked to the cabin, had a little Jack and some dinner. Went to bed. Fixed it all in the AM and finished the job.
This was several years ago - and I still feel like an idiot. Darned lucky there was no major damage - and no injuries.
Z.
/ So this happened. BXPanded Underarmor destroyed. #36
I mangled the steps on a stump obscured by brush on our JD 6200. That alone, didn't annoy me as much as the fact that the JD replacement was of flimsier construction, than the original.
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2022 EZ-GO ELITE...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
Bad Boy Stand On Mower (A64047)
Bad Boy Stand On...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
