Snowplow
/ Snowplow #11
Mark,
Thanks for your response and the pic.
First, seeing all those gorgeous dark-green conifers in March makes me wish I was heading to Vermont THIS year and not next. (sigh)
It looks like you have a little bit of grade. Mine will be about the same except 1200' longer. If the 950/turf tires/MFWD can push through that, then I'm VERY encouraged.
My other needs will be mowing and firewood, so hopefully 20-something HP will do the trick.
Thanks again for sharing your thoughts. It's all helpful. I have the advantage of time to be able to process all the info that's coming my way.
/ Snowplow #12
Marc,
You will find a Wealth of Knowledge, information and inspiration at the TBN. As a new member we welcome you.
The only reason my tractor has the turf tires on it is because they were on it when I bought it. I am only the the 2nd owner it it's 14 yrs. It was originally owned by a condo development about 5 miles from me, for all there yearly maintenance needs.
I have been impressed with the ability of the turf tires, although when I trade up to my TC35D in a year or so I will probably go with the R4's.
Irrelevent of what you choose for tires, you always have the option of installing chains when necessary to supplement your traction. I plowed all winter with no chains and using my backhoe for weight and seldom ever lost traction.
/ Snowplow #13
I did that very thing with a Meyers 7 1/2 power angle plow. I did not use the power angle function but I built and installed a mount to accept the plow in the bucket of my Ford 8N.
I liked plowing with the tractor better than with the truck except the tractor did not have a heated cab. The plow could be attached to the truck or tractor, however it was easier to attach it to the tractor.
A fellow up the road from me has a Kubato M-series with a snow plow mounted in the bucket, works great.
Randy
/ Snowplow #14
Youare:
How deep did the snow get and did you do anything for added traction?
/ Snowplow #15
I used this set-up for about 12 years durning that time we had several storms that dumped over 2 feet of snow. I did have my Farmi winch on the rear of the tractor which must weight around 350 pounds and one winter I put an additional 125 pounds on.
My driveway and the road I plowed are dirt, so the ice would build up over the winter, I did have a set of non-agressive tire chains to help out. They were old fire truck tire chains that I made fit the tractor tire.
The nice thing about having the plow on the bucket is you can push the snow banks way up. I had some after a big storm that we 8 feet high.
Randy
/ Snowplow #16
Also w/a plow attach to the bucket...one doesn't have to get that close to a ditch line fearing of bottoming out.
/ Snowplow #17
Marc, Reference size tractor to plow snow. I live in So. Maine and plow with my 23HP Cub Cadet, (7234) 4WD tractor. When I was researching tractors before I bought this I made up a spread sheet comparing features etc. The Cub was the best price so that is why I got it but it also had a lot of nice features plus it was heavier than a similar JD 770 or Kubota models. It is in the 33-3400 pound range w/FEL attached and it has large 41" rear turf tires. I plow mostly up a hill from where the tractor is garaged. We had little snow this year but last year was a killer. Most of my snowbanks were easily in the 6 -7' range, far higher than the 4WD pickups could push it. I have some wheel spinning but plow with no weight on the rear. I was going to buy chains before my first season because a friend with a JD 770 had weighted tires w/chains. He experienced a lot of traction problems that I really haven't had. When you buy I think the weight, HP, are probably a couple of your most critical components to consider but it is amazing what these compact 4wd tractors will do. If I bought again I would get a HST and just a little more HP to handle any HST power losses. Happy hunting for the color that meets your needs. Don't rule out the Bright Yellow ones!
/ Snowplow #18
Thanks MAJMAC, Mark, Thomas & Youare. This is definitely a great help to hear form the guys who have done this already.
/ Snowplow #20
Rowski,
I just looked at your bio. Looks like I'm moving to your neck of the woods - about halfway between Jay & Newport Center.
WATER TRAILER (A58214)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
John Deere Hopper Assembley Kit (A60463)
John Deere Hopper...
Trailmobile Van Trailer (A61307)
Trailmobile Van...
2020 DRAGON ESP...
Can-Am Commander Rotax 1000 (A60463)
Can-Am Commander...
