Snowblower Snowblower Conversion
/ Snowblower Conversion #1
Marko
Derry , NH
2002 JD4110 HST
All ,
I have a 1 year old 48" snowblower from my lawn tractor (belt drive). I was wondering if there is a conversion kit that would replace the belt system for a PTO Shaft system. I was thinking of using this off of the 3PH on my JD4110
Mark
/ Snowblower Conversion #2
I doubt you can buy a conversion off the shelf.
Don't know what your fabrication skills & equipment are, If one or both is low, you may be better off selling the blower & buying a 3point one ($1000 +/-).
Don't get me wrong, it can be done if you're handy & have the tools. If you had to pay someone to fab the parts it could get expensive fast.
Good luck!
/ Snowblower Conversion #3
If I recall correctly (which is a BIG "if"), JD makes a kit to adapt the larger garden tractor implements to the 4100 series tractors. That may be a good starting point if you want it on the front of your 4110 /w3tcompact/icons/smile.gif
Haz ,
Know of any good 3PH blowers ??
Mark
/ Snowblower Conversion #5
Rob,
You are correct, but I think the 400 series attachments are shaft driven, not belt! I'm sure the mower is & assume that the snowblower is too.
Mark,
Haven't used a 3point blower so can't really recommend one. Do a search here, many have been discussed.
PS try "snowblower", "snow blower" "snowthrower" and "snow thrower" the space may make a difference.
Also call the local dealers & ask what they carry, then you can ask here if anybody's got one.
/ Snowblower Conversion #6
Mark, I have a 42" White single stage blower that my father converted into a 3ph unit. Bought a gear box from a local supplier and mounted it on a plate and bolted that to the back of the blower. Made the 3ph out of flat bar stock. Relatively easy, but...bear in mind that when blowers break it's because there's a ton of snow outside and you probably have no choice to clear it.
I bought a 54" Puma from Pronovost. It's decent, but nothing to write home about.
2016 FORD TRANSIT 350 PASSENGER VAN (A66091)
2016 FORD TRANSIT...
PALLET OF METAL BRACKETS (A68842)
PALLET OF METAL...
2024 Argo Explorer XR150 (A64912)
2024 Argo Explorer...
MACK SINGLE AXLE(INOPERABLE) (A67714)
MACK SINGLE...
217982 (A65054)
217982 (A65054)
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
