snow removal options
/ snow removal options #31
Wood ash is about as best as it gets for traction on ice or hard pack snow
It's good, but beware using it close to the house. Easy to track in a mess and can eat away at rubber soles if left on them (can make lye from ash, quite alkaline).
/ snow removal options #32
The driveway is 2RC stone. As for anti skid I built a tow behind cinder spreader a few years ago. It broadcast coal cinders and really helps with the ice. I was thinking a John Deere 46" single stage blower would fit but could be mistaken.
The 46" will fit, don't worry about it, it was an option when the 2305's were selling new.
ok I guess most everyone agrees the two stage is better then the single stage on a stone drive.
/ snow removal options #34
Previously I voted for a front angle plow not knowing your drifting problem. Given the drifting, snow blower makes sense for those sections of drive. The two stage blowers seem to be a more effective design esp. if you don't have a lot to push it.
You may want to put a snow fence up for the short stretch where your drifting is a problem. Could save you some time.
I never thought I needed a blower but now have the opportunity to try one for free. My cousin picked up a 72" twin auger two stage beast of a blower for the price of scrap metal ($300). It is as heavy duty a blower as I've seen. His tractor can't lift it so he's not using it. Hope we get a snow big enough to put it to the test!
/ snow removal options #35
Gladehound, I do put up 200 ft of snowfence. It helps but doesnt cure the problem.
/ snow removal options #37
Yes, agree the fence only helps.. for me it just means I don't have a 4 ft. drift to get through in the morning, rather only a few inches of snow/drifting, which I still have to clean but when I get home from work is better than before work. It also means less snow to deal with overall.
/ snow removal options #38
I've had a gravel driveway for 40+ years and have used single and dual-stage walk-behinds and more recently a tractor mounted 2-stage.
They ALL will fling gravel at high speed! If not careful. the two stage will gather gravel and rocks, feed them into the second stage impeller and fire them out the chute at high speed.
I would go so far as to say 2-stage blowers will throw gravel FARTHER than a single-stage.
I was thinking of the smaller walk behind single stage units where the rotor sweeps the ground directly (and clears nicely to bare pavement) but will fling gravel more. As shown here Snow Blower Buying Guide - How to Pick the Perfect Snow Thrower
/ snow removal options #39
/ snow removal options #40
I think the main reason why those aren't suitable for gravel is not because of the single stage design, but rather because most of those do not have adjustable skid shoes. Most normal walk-behinds have skid shoes which can be adjusted to set the height of the cutting edge. If using on pavement you can lower the skids and have the cutting edge scrape the pavement bare. With gravel you want to adjust the cutting edge an inch or more above the gravel to avoid gathering stones.
On my old MTD walk-behind I had the skid shoes set at around 2-inches.
2006 Freightliner Auger Truck (A61307)
2006 Freightliner...
LOT LOCATIONS (A59908)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Electric Golf Cart (A56859)
Electric Golf Cart...
43024 (A59228)
43024 (A59228)
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
