Snow Attachments Snow PUMP
/ Snow PUMP
Re: Snow PUMP [engine #2 ]
That appears to be a water to water heat exchanger such as would be used on a engine on a boat so that you run your lake or river water through the small pipes that you have identified as in and out and then your coolant runs through the larger pipes. If you were to look inside the long tube there is probably a U-shaped piece of copper pipe with fins on it that goes from the inlet to the outlet and is surrounded by the engine coolant.Aaron Z
I uploaded a 2mb picture, don't know where it got so small. I know about the water2water detail, and you gotta be right about the finned loop or coil inside, it just wouldn't make sense any other way. I'll get some plumbing fittings tomorrow, remove the rack with all the valves and connect a hose, planning to choke outflow with a sprinkler nozzle to keep it 'not more than just warm'. I need to warm the engine up to see if cold coughing above idle is temp. related.
/ Snow PUMP #182
That's a heat exchanger. Just run your garden hose through it. That'll be lots of cooling to just let it run with no load.
Edited to add: I looked at the picture again. I wouldn't change too much on it. I'm thinking that if you ran antifreeze from your vehicle through the heat exchanger there would be more than enough cooling in winter.
The two "Y's" at the bottom are inline filters along with some pressure regulators. It looks like the valves are set up so that you can run water through either filter setup. If your going to test make sure you run water in at the bottom. That way the heat exchanger stays full of water.
/ Snow PUMP #183
You have a turbocharged engine there with straight water to water cooling substituting for the radiator and aftercooler.
You have two sets of ball valves and Y strainers there as well with the ball valve in the upper pipe loop removed, its best to check to see if it is closed or open before you go any further as the galleries are most likely empty of water to prevent it from freezing and cracking the block.
Your going to need a radiator and after cooler if you expect to use this engine.
/ Snow PUMP
Thanks for the info, I already removed the plumbing rack so at least temporarily I'm just running a hose through the the jacket. Ultimately when on a snow blower the cooling might be less of a problem, keeping the preset setup with another prestone radiator on tyhe water-jacket primary side could be an idea but that's still far down the road. After about 10 minutes of idle there was nearly no increase in the draindown temperature but I figured that the engine was warm so I then tried to go above idle for a few minutes. I just uploaded about 250mb of temporary stuff to (view an image separately for much better res). I have to apologize for not having thought of reducing the file sizes, it's a looooooooooooong loading page, will fix that too tomorrow...
http://trixtar.org/temp-pub-buffer/2017-07-early-data/index.html
with initial id pictures and a short video. The engine seems to smoke too much at idle, and coughs and barks above idle but I don't hear any dramatic noises. I didn't feel good about pushing it at this stage. Funny how much less a video tells when you cannot see the smoke stack, I'll fix that tomorrow with a better video.
It's too early and my familiarity with this engine is zero, LOTS of questions remain. The injection pump is a lucas and I might have to learn to time those, one possibility is retarded timing but I have no idea if these lucas jobs can slip off-time like the p7100's can. I'll be trying to get spooled up on such issues tomorrow.
/ Snow PUMP
Had the injectors tested today, 3 of 6 were waaaaay out leaking and dripping or even flowing like a hose at higher pressures , I don't know how that can be with an engine that has only 1300 hours. Anyway all 6 are going in for rebuild/replacement and I'll run the engine again when I get them back.
/ Snow PUMP #186
if the fuel was not filtered down to 2 micron this is the result.
/ Snow PUMP
With nozzle sizes upward of .010 I don't see how 5 micron particles would destroy an injector spray/mist pattern. The filter on it is a Baldwin BF788, the engine was in a Cascade factory as a firepump driver, possibly since new. I'm only guessing that if you raise the pressure high enough than even a 3/4" hole will produce a mist, so it would be intesting to know what the test pressures were as opposed to what they should have been but I didn't get that info. Those springs should certainly not weaken in 1300 hours so there again I'd be at a loss trying to finger out the issue.
BTW, don't the 2 micron filters require some workaround footwork involving flow and freezeing up?
/ Snow PUMP
Any updates on this fitterski? Feeling pretty chilly out here in NH.
Busy with related subroutines such as engines, in fact for this next season I'm going to use the old rig as-is for it's 9th (i think) winter. I bagged 2 Cummins 12-valves one of which will go to snow blowing next year. One is a 208hp one that's in pretty good shape except for some mysterious bug (can't link off hand but you'll find it under my handle on this forum), the other one is a 175hp truck survivor that just went to the machine shop for some work. BOTH are low-timers and generally in A1 condition so I'm very happy and confident in the 'power-plant' department.
Once I have commited to one of the engines (likely to be the automotive one after all) I'll decide about the first platform to attempt it on. My son insists I should stick with the existing rig (it's more exotic than some 'truck'). Concurrently I wrapped myself around a novel 3-point idea to make truck use less involved i.e. not necessarily requiring a dedicated truck at all. It revolves around a 3-point interface that is actually ENTIRELY on the implement with its hydraulic cylinders and all and nothing more than 3 discrete *hard-points* on the truck (2 of them being the front hooks). I may need to relocate the radiator, maybe not even that. The idea would be to use my everyday truck in otherwise instant drop/pickup mode. If I go the truck route later, with reference to trucks that exist today, the RAM 3500 will be _it_. One look at that thing on my back underneath it convinced me.
So that's it in a nutshell, there WILL be more discussion this winter. I also got me a hydraulics expert to run to for some advice as that avenue hasn't been discounted either, not at all although it is pricey :laughing:
/ Snow PUMP #191
Any more progress ??
/ Snow PUMP
No, I'm operating the existing rig in its 9th or whatever-th season, I got two engines standing by for blueprinting for the project with all parts already on the bench and all machine-shop work done on one of them. I've been lazy as per SOP this time of year.
i LOVE your freaking sig!
One element of the new project plan is the previously outlined possibility of using a Ram-3500 host platform sporting 2500lbs on the nose. I'm thinking of using the (reinforced) front hooks as 2 elements of a 3-point, i just need a 3rd *hardpoint* of sorts at about mid-height between the radiator and the grille so that the truck would be 100% street legal when not blowing snow. Incorporating such a hardpoint withOUT the ususal brain-dead "if it breaks make it bigger and ugglier" plow rack is what I'm kicking around these days. I would put ALL but the hooking attachment actuators on the blower itself instead of on the truck, this should make the idea executable and I won't have to dish out another $500/yr just to keep another vehicle in plates!
I once owned a '62 Lincoln convertible with some neat electrical screw-locks on the top-swallowing trunk lid. Three small hydraulic motors along those lines on 3 hardpoints could facilitate approaching and latching the blower without getting out of the seat.
The plan is to get one of the engines done by summer and then either adapting to the existing rig or going for a truck.
/ Snow PUMP
Go look in pics of your snow weapons post #4012 or so. Someone posted a picture of a rig that is what you are trying to build. http://www.tractorbynet.com/forums/snow-removal/184041-pictures-your-snow-weapons.html
Yeah, I've seen MANY like it but that isn't what I'm after *at this point* in case I opt for a truck platform. Those chain hoisted plow racks weigh a ton and are the type on-in -October/off-in-April. I'm not dismissing it, but will first try to think up something simpler, cleaner, lighter, faster. I would also have some questions about that front suspension and load capability, just off hand and not really knowing the weight of that blower with rack and hyd-motor.
/ Snow PUMP #195
What are you after then I'm curious?? The one I posted about it a permanent snow blowing truck. Has a hilo mast to lift, not a plow system, and has a motor in back driving the hydraulics for the blower like what you want.
What else are you looking for??
/ Snow PUMP
I'm thinking of using the two front tow hooks (or a stronger version of them) as the two lower points of a 3-point system. Compared to a tractor's 3-point the difference would be that everything else would be on the blower so that the blower would be articulating and moving itself as opposed to the tractor/truck moving it. What this means in theory is nothing more on the truck than the 3 strongpoints to latch to (a kind of quick-attach system). The third one would need to be right about in front of the middle of the radiator behind or flush with the grill. If I cannot cook up anything like this THEN I'll consider a more or less permanent or seasonal installation method like the one in post you linked.
/ Snow PUMP #197
/ Snow PUMP #198
/ Snow PUMP
The first engine bagged (and to enter service) in this project is coming along nicely. It's my second diesel and first Cummins build. I've learned a lot of respect for Cummins in the exercise, for example the way the power steering pump is done. It's exactly how "I" would have done it. Let's face it, loosing steering boost on a half-serious truck is a distinct accident risk so a solid drive instead of the belted pump makes points with me. I won't even mention the current fad of electrically assisted steering solutions.
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A65563)
2011 Ford F-350...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
Champion X18A Air Compressor (A65640)
Champion X18A Air...
