fitterski
Gold Member
- Joined
- Oct 20, 2016
- Messages
- 378
- Location
- Nouvelle, QC
- Tractor
- 1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
Re: Snow PUMP [engine #2 ]
I uploaded a 2mb picture, don't know where it got so small. I know about the water2water detail, and you gotta be right about the finned loop or coil inside, it just wouldn't make sense any other way. I'll get some plumbing fittings tomorrow, remove the rack with all the valves and connect a hose, planning to choke outflow with a sprinkler nozzle to keep it 'not more than just warm'. I need to warm the engine up to see if cold coughing above idle is temp. related.
That appears to be a water to water heat exchanger such as would be used on a engine on a boat so that you run your lake or river water through the small pipes that you have identified as in and out and then your coolant runs through the larger pipes. If you were to look inside the long tube there is probably a U-shaped piece of copper pipe with fins on it that goes from the inlet to the outlet and is surrounded by the engine coolant.Aaron Z
