Snow Plowing a Gravel Drive - Problem Solved!!!
   / Snow Plowing a Gravel Drive - Problem Solved!!! #81
Yes I assume casters would work but I am not a fan especially in the winter - I would think the casters would be digging in and leaving a trail of marks etc. I prefer a nice clean look.
I’m sure they would freeze up and then the wheels wouldn’t turn. Then they would drop down and dig into the gravel like skid shoes.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #82
I know this is an old thread but I had a Fisher V plow that used a rubber flap in the middle for proper clearing. Well I cut out two pieces of a stall mat so it could be 2x as thick. Even used fender washer for backing. It didnt even last 2 storms. They do bend alot though. Cutting the piece out of a bias ply tire worked for years after that and sold it working.
On a side note..all the big parking lot snow pushers you see usualy have a rubber edge thata very very thick. That's how they clean so well.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #83
When you analyze how windshield wipers work you'll soon accept why stall matt strips do so well on a plow blade.----- I.E.- you are wiping, not scraping.
I'll repeat my solution of cutting matts:
Simply drape the matt over a 2 x 4 and use a fresh blade and some sort of guide.
Draping will open up the cut as U move along and greatly reduce friction.
   / Snow Plowing a Gravel Drive - Problem Solved!!! #84
When my mile long gravel driveway has not yet frozen hard - I reverse the rear blade 180 degrees and go like smoke and oakum.
This works fine for me. Gravel stay where its been placed - snow bladed to the ditches.
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
2019 Chevrolet Silverado 1500 (A55973)
2019 Chevrolet...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A57880)
2020 INTERNATIONAL...
2014 Freightliner M2 (A55973)
2014 Freightliner...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
