snow plow
/ snow plow #1
wr400
wisconsin
2000 Jd 990
Okay I have a 8' western snowplow. I even have the pump for lift an turning. I am kinda wondering if I can just mount the plow to my loader an use the Bucket hydo to make the plow shift left an right. Thoughts were to get two extended Hydro lines to go from the plow cylinders to the quik attach copplers on my JD 990.
Will it work?
/ snow plow #2
Yes, it will work. Do a search for these terms to see how others have done it:
FEL plow
FEL snowplow
HERE is a post I did on mine when I built it.
/ snow plow #3
Yes that will work just fine. For years I used my rear remote to angle my plow. Now I have a third function and use it for the plow angleing and my grapple. An 8 foot plow may be just a bit to much for your 990. Good luck.
/ snow plow
Thanks for the info! Yours is pretty nice. Mine I had thoughts of useing the western mount an just use the chain on the plow if I needed to lift. Now I may have to rethink that.
/ snow plow #5
This is what mine looked like when it was on my L 3830.
/ snow plow #6
That is what I don't like about loader plows.... they stick out 8' beyond the front tires. Easily push around especially on ice. On a frame mount I can angle the blade and have it within an inch or two of touching the front tires.
/ snow plow #7
I was plowing 2 feet of snow last winter and it never pushed me around. I used that rig for 5 years and the only time it pushed me sideways was when it dug into unfrozen ground.
/ snow plow #8
Is this to say that by having the plow closer to the front tire that you will not get pushed around.
/ snow plow #9
As long as you have your shoes set on the plow so that the blade doesn't dig in you won't have a problem. At least I haven't yet. The other plus is the farther it sticks out, the farther you can push it over a the edge of your drive or snowbanks.
Steve
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2019 Ford F-450 Knapheide Service Truck (A66736)
2019 Ford F-450...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A66734)
2025 GIYI GY-P45...
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
