snow plow
/ snow plow #1
wr400
wisconsin
2000 Jd 990
Okay I have a 8' western snowplow. I even have the pump for lift an turning. I am kinda wondering if I can just mount the plow to my loader an use the Bucket hydo to make the plow shift left an right. Thoughts were to get two extended Hydro lines to go from the plow cylinders to the quik attach copplers on my JD 990.
Will it work?
/ snow plow #2
Yes, it will work. Do a search for these terms to see how others have done it:
FEL plow
FEL snowplow
HERE is a post I did on mine when I built it.
/ snow plow #3
Yes that will work just fine. For years I used my rear remote to angle my plow. Now I have a third function and use it for the plow angleing and my grapple. An 8 foot plow may be just a bit to much for your 990. Good luck.
/ snow plow
Thanks for the info! Yours is pretty nice. Mine I had thoughts of useing the western mount an just use the chain on the plow if I needed to lift. Now I may have to rethink that.
/ snow plow #5
This is what mine looked like when it was on my L 3830.
/ snow plow #6
That is what I don't like about loader plows.... they stick out 8' beyond the front tires. Easily push around especially on ice. On a frame mount I can angle the blade and have it within an inch or two of touching the front tires.
/ snow plow #7
I was plowing 2 feet of snow last winter and it never pushed me around. I used that rig for 5 years and the only time it pushed me sideways was when it dug into unfrozen ground.
/ snow plow #8
Is this to say that by having the plow closer to the front tire that you will not get pushed around.
/ snow plow #9
As long as you have your shoes set on the plow so that the blade doesn't dig in you won't have a problem. At least I haven't yet. The other plus is the farther it sticks out, the farther you can push it over a the edge of your drive or snowbanks.
Steve
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
New Holland 499 MoCo (A66408)
New Holland 499...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT4EHFV0598 (A65563)
2014 Freightliner...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
Conveyor Belt (A64194)
