Snow Equipment Owning/Operating Snow plow damaging tractor?
   / Snow plow damaging tractor? #41
Does Curtis supply a cross over relief valve on their FEL mount snow plows? What is the small block with hyd. hoses attached for in the pic?
How about mounting a snow plow on a full size backhoe loader? Does anyone see any harm in that?
   / Snow plow damaging tractor? #42
Plow my driveway and neighbors etc. for 14 years w/this setup,never had problem other than hitting mailbox handful of times :(..go slow until you get the hang of it. :)
   / Snow plow damaging tractor? #43
I just use a 12' "pusher box" when I do snow removal with my backhoe. It hangs off the FEL bucket. Been doing that for 20 years. Still haven't broken a loader arm with all those extreme torsional forces.:rolleyes:
The do make power angle snowplows for backhoes. My Case 580 had a FFC quick attach front coupler that would take a variety of equipment like PA plows & power brooms.
Sweepers - Skid Steer Attachments - Paladin Light Construction
Henke Manufacturing - Snow Removal Equipment
   / Snow plow damaging tractor? #44
Yes, that is it with the hoses attached to.
I have nearly the same plow.
   / Snow plow damaging tractor? #45
Do you have any photos of this set up?
   / Snow plow damaging tractor? #47
Thomas, Are you going to use this setup on your new tractor ?
   / Snow plow damaging tractor? #49
I believe the "Torsional Forces" only come into play when you angle the blade and put a side load onto the loader frame. A pusher box is just that a box not unlike using the loader bucket itself to move snow. That would not create any side loading as they are not angled (at least the ones I have seen are not).
I would think a straight blade would also work fine as that should not create any side loading on the loader frame. I am contemplating picking up a used plow off Craigslist and welding the blade so it does not angle, leaving the trip springs and then putting a skid steer type Q/A plate on it so it would replace my bucket. That should not create any issues unless I ram something solid which would also be a problem when using the bucket to. I currently use just the bucket for snow removal so a blade should be an improvement.
   / Snow plow damaging tractor? #50
johndeere4300
"Are you going to use this setup on your new tractor ?"
Yes Sir..heavier frame w/7'6" plow this time but same height.
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
200 Gallon Tank (A57148)
200 Gallon Tank...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
More info coming soon! (A55851)
More info coming...
