snow plow cylinder source
/ snow plow cylinder source #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I have a old 78" Meyer snow plow I am attaching to the front of my JD loader with skid steer attachment. I doesn't have any hydraulic cylinders and would like to add. I already have the front hydraulic lines on the loader. It has the bracket for the cylinder on both sides with a 20.5" spacing in the middle position (17" closed and 25 1/4" open). Any ideas for source or type of cylinder? Is one dual acting cylinder OK or do I have to have 2 single acting cylinders?
/ snow plow cylinder source #2
I have an old Meyer plow that had two single acting cylinders. You can go with those or you can use one double acting cylinder. I think you can get replacement cylinders at Surplus Center or Northern Tool on-line. You can use one that is a bit shorter stroke, but if you use one that is a bit longer stroke, you could bend the plow or brackets.
/ snow plow cylinder source #3
Meyer's uses SA cylinders, 1 1/2" x 10" on the smaller plows, and 1 1/2" X 12" on the larger plows.
Look here...
Untitled Document
Thanks for the info. That should get me started.
radman
Ok, now have another question. How are the hoses run to the cylinders if I use 2 one-way clinders? I have 2 couplers on the tractor. Does each cylinder just get one hose?
/ snow plow cylinder source #6
That's exactly correct. As one cylinder expands it forces the opposite cylinder to retract. A simple system that actually works.
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59910)
2006 STERLING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
24" X 84" METAL SHELVES (A63745)
24" X 84" METAL...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
240 Massey Ferguson Tractor (A61165)
240 Massey...
