snow plow cylinder source
   / snow plow cylinder source #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I have a old 78" Meyer snow plow I am attaching to the front of my JD loader with skid steer attachment. I doesn't have any hydraulic cylinders and would like to add. I already have the front hydraulic lines on the loader. It has the bracket for the cylinder on both sides with a 20.5" spacing in the middle position (17" closed and 25 1/4" open). Any ideas for source or type of cylinder? Is one dual acting cylinder OK or do I have to have 2 single acting cylinders?
   / snow plow cylinder source #2
I have an old Meyer plow that had two single acting cylinders. You can go with those or you can use one double acting cylinder. I think you can get replacement cylinders at Surplus Center or Northern Tool on-line. You can use one that is a bit shorter stroke, but if you use one that is a bit longer stroke, you could bend the plow or brackets.
   / snow plow cylinder source #3
Meyer's uses SA cylinders, 1 1/2" x 10" on the smaller plows, and 1 1/2" X 12" on the larger plows.
Look here...
Untitled Document
Thanks for the info. That should get me started.
radman
Ok, now have another question. How are the hoses run to the cylinders if I use 2 one-way clinders? I have 2 couplers on the tractor. Does each cylinder just get one hose?
   / snow plow cylinder source #6
That's exactly correct. As one cylinder expands it forces the opposite cylinder to retract. A simple system that actually works.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
2018 John Deere 1025R Tractor - 257 Hours (A55314)
2018 John Deere...
