Snow blower width
/ Snow blower width #2
I go by the rule that the blower should just clear the rear wheel width. A 6-1/2 foot would be the perfect size.
/ Snow blower width #4
I would say atleast the width of your rear wheels at the narrowest setting your comfortable with. If the tires are non adjustable you pretty much have your width. If the blower is to narrow, you pack down the snow before you ever get to blow it. i think there is a wide range of horsepower requirements based on whether the blower is a single or dual stage as well. You can always drive slower if the blower is just a bit to big though.
/ Snow blower width #6
I don't know about HP, but my 47" blower is just a hair narrower than my JD 2520, and it bugs me.
Wish I had a 54"er.
/ Snow blower width #8
Ideal is 6" wider than tires! and minimum no less than 3"
Believe the recommendation is 5 hp per foot but this is less critical with hydrostatic as you have control as to how big a bite you take.
/ Snow blower width #9
The hst part is a myth, have just as much control with a gear trans, especially a powershuttle.
/ Snow blower width #10
that may be a 'qualified' myth, Will... years ago I had a Bolens 1050 with a 36" single stage blower on the front. Even in 1st gear low range, I was riding the clutch a lot in heavy snow... HST would have been nice.
You could argue a Bolens 1050 is not a real tractor, I suppose... but it did a lot of work for me the 28 years I had it.
Pete
/ Snow blower width #11
Seen a graet deal on a 5 ' but thoght it was too small.
Thanks.
Get the great deal on 60" and add "wings" to each side!
I added them to my 51" to a total width of 63" and it works great (dare I say even better than stock?)
/ Snow blower width #13
/ Snow blower width #14
Pete
I love tjose older garden tractors. I wish they were stillbuilt like that. Dad had an MF 12, then a Ford LGT165.
/ Snow blower width #18
It is no Myth!
A Hydro transmission has infinite speeds so you can feed the snow blower into the snow as fast or slow as the engine HP allows. Gear transmissions do not allow this so when you encounter extreme conditions (heavy deep snow) excessive use of the clutch is needed to avoid stalling.
I live in New England and my 28hp (24 PTO) 1720 Ford SSS with 12 forward & reverse gears would frequently run out of power even in 1st gear using a 64” snow blower. Constant use of the clutch was necessary to prevent stalling the engine. I would consider this abuse of the clutch.
Just to clarify my tractor is not running poorly. I eventually I installed a turbo and the increased HP which solved my problems.
A smaller Hydrostatic Ford tractor using the same snow blower handled it with no problems. Ground speed is the key to proper operation.
Correct me if I’m wrong but a power shuttle still uses forward & reverse clutches and are still wear prone.
Based on my personal experience with up to 12~18 inches per storm and snow banks that are 24~36 inches high I would agree that a (minimum) of 5 preferably more are required per foot of width.
As for width 4 to 6" wider than the tractor is the minimum.
90cummins
/ Snow blower width #20
Not to hi-jack this thread but "Doxford Jim" where can one buy the "extension wings" like you have.................. the yellow ones look like perfect size to expand my 30 + year old J.D. 666 snow blower (looks similar to yours).
Carl (Thanks so much)!
Bomag ProTack TW500 T/A Towable Asphalt Patcher (A64553)
Bomag ProTack...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64553)
2017 Caterpillar...
AUCTION STARTS HERE @ 9AM (A64278)
AUCTION STARTS...
2015 20ft T/A Diamond Cargo Enclosed Trailer (A64557)
2015 20ft T/A...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
