Snow Blower chute controls
/ Snow Blower chute controls #1
PeterK
Central Maine
Kubota BX24 TLB
Sorry. I just spent too a lot of time writing a description and lost it when I went to add the image. So all you get is the image since I don't have the time to do it all over again. I will look back and respond later, too busy this am. This schematic will control one axis so you will need two to control both the left-right and up-down.
If you don't already have electric motors to control the chute, search the forum. This is just for controls.
I had been using DPDT momentary rocker switches and they work great, just not at my finger tips . So this prompted me to use some sort of 4-way SPST switches that I could mount on the loader control lever. I ended up using a 4-way joystick from eBay. It has 4 individual micro switches which are perfect for the task of switching the ground to the relay coil. I will mount it in a small project box and attach that to the loader arm. It needs 5 small wires to complete the ground (which energizes the appropriate relay by completing the power circuit to the relay coil.)
I am using Bosch 5-pin style relays and dual sockets from http://www.PartsExpress.com They're high amperage, actually much overrated for the window motor that I am using for rotation. But easy to find and reliable. You can also get waterproof relays if you think that you will need them. The 4 relays and fuse will mount to the left side of the center console support. Might even add an aux fuse panel if I find enough room in there.
On the business end of the wiring, I use WeatherTec connectors which plug into the harness from the blower. Makes R&R easy and these are weatherproof, important since they are outside in the elements.
Anyway, hope this schematic helps. There is a lot out there but no real wiring diagrams that I found so here's mine:
/ Snow Blower chute controls #3
Clean and simple and inexpensive. I did much the same. Nice job.
/ Snow Blower chute controls #4
I had made the cab many years ago, now with the blower it's great. Also added heat and back up cam. Snow Blower.jpg
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
213088 (A64276)
213088 (A64276)
2018 RAM 5500 FLATBED (A67714)
2018 RAM 5500...
2018 CHEVROLET 3500 SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
